Old 01-15-2022, 03:12 PM   #41
nomoresonys
City & State: midwest
My Country: U.S.
Default Re: Sony xbr65x900c sound yes, no backlight or image.
Took 1 cap out, tested board on the bench, got 167 on main filter cap with just power connected, jumped 5 and 7 stby-poweron, filter cap only rose to 274, isn't that way too low or is it only partially on at that point?
nomoresonys is online now   Reply With Quote
Old 01-15-2022, 03:46 PM   #42
Diah
City & State: SA
My Country: Germany
sound good.. did you messured any voltage on the socket ?
Diah is offline   Reply With Quote
Old 01-15-2022, 04:00 PM   #43
nomoresonys
My Country: U.S.
Yes, the 12 volt pins are still 0, still have zener 909 reading short.
Old 01-15-2022, 04:04 PM   #44
Diah
City & State: SA
My Country: Germany
Yes, the 12 volt pins are still 0.
did you measured the 12V on the socket with references the black probe on the COLD ( secondary ) area chassis ??
Old 01-15-2022, 04:15 PM   #45
nomoresonys
My Country: U.S.
For ground I used the ground screw holder thats metal labeled gp4 on the board.
Old 01-15-2022, 04:19 PM   #46
nomoresonys
My Country: U.S.
Still wondering why ZD909 reads short in circuit and none of the others do??
Old 01-15-2022, 04:38 PM   #47
Diah
City & State: SA
My Country: Germany
but out of the board it read correct... right?... did you searched on the ic spec close to the zener
Old 01-15-2022, 04:40 PM   #48
nomoresonys
My Country: U.S.
Yes, will retrieve data sheet, thanks.
Old 01-15-2022, 04:45 PM   #49
nomoresonys
My Country: U.S.
It's a a6069h, I think this is the equivalent: https://datasheetspdf.com/datasheet/STR-A6069H.html
Old 01-15-2022, 04:47 PM   #50
nomoresonys
My Country: U.S.
Can I test that in circuit? thanks.
Old 01-15-2022, 05:06 PM   #51
Diah
City & State: SA
My Country: Germany
its okay, as you have standby viltage
Old 01-15-2022, 05:13 PM   #52
nomoresonys
My Country: U.S.
Thats a relief, don't have to deal with that dam thing, thanks.
Old 01-15-2022, 06:28 PM   #53
nomoresonys
My Country: U.S.
What is a puzzle is that zd909 did not test short in circuit til after the caps blew??
Old 01-15-2022, 08:10 PM   #54
R_J
City & State: ☻
My Country: Canada
Is ZD909 across R907A/R907B? I suspect those are the source resistors for the ic's internal mosfet and are usually around 1Ω or less
R_J is offline   Reply With Quote
Old 01-15-2022, 09:53 PM   #55
nomoresonys
My Country: U.S.
Thanks for reply, yes it is across, both are at 2.2 ohms. They both continually beep in diode mode like a fuse does.
Old 01-15-2022, 09:57 PM   #56
nomoresonys
My Country: U.S.
Of all the little resistors on underside theres 6 that continually beep. The rest don't.
Old 01-16-2022, 04:13 AM   #57
Diah
City & State: SA
My Country: Germany
i still think you have open circuit some where.. lets do this beside the jumpers you did STBY3.3V with Power_on, put another jumper between STBY3.3V and BL_ON then measure if you have any voltage over the secondary area not only the socket.
Old 01-16-2022, 10:33 AM   #58
nomoresonys
My Country: U.S.
I think your right Diah, with those 3 jumped I have 275 v on main filter cap, I checked the 4 electrolytic caps right by the connector but there's 0 volts on all of them, does that make sense? thanks.
Old 01-16-2022, 10:37 AM   #59
nomoresonys
My Country: U.S.
Still no 12 v, strange because I'm pretty sure I measured once and all the 12's were there with everything hooked up, right after I replaced the blown caps.
Old 01-16-2022, 10:44 AM   #60
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
I'm a: Hobbyist Tech
on the psu secondary side the 3amp resistor type fuse i guess you have checked that?
vinceroger69 is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2022
