Old 01-27-2022, 05:35 PM   #21
Diah
City & State: SA
My Country: Germany
Default Re: Sony KDL-40BX450 LCD. Thermistor gets too hot 10 seconds after turning on the TV
Originally Posted by Quantum IC View Post
When I press the power button for the first time after plugging in the TV, the voltages are present for about 1-2 seconds and then drop to 0V, except for the STBY 3.3V and AC OFF DET 3V voltages, which are always present.
Then when I press the power button again the TV turns on and all the voltages are present.
common man.. did you read about Sony firmware it can register failure account.. what the eeprom will do if the sectors space are full...it will try to shutdown then delete the last one and turn on again normal.. log in SM and clear this register.
Diah is offline   Reply With Quote
Old 01-27-2022, 05:58 PM   #22
nomoresonys
City & State: midwest
My Country: U.S.
That sounds right to me Diah, I do believe you are correct sir.
nomoresonys is offline   Reply With Quote
Old 01-28-2022, 09:11 PM   #23
Quantum IC
City & State: New York
My Country: United States
Line Voltage: 110VAC 60Hz
How can I log in SM and clear the register?
I don't have the remote and the owner of the TV lost it.
Quantum IC is offline   Reply With Quote
Old 01-29-2022, 01:39 AM   #24
gabiz_ro
City & State: Bacau
My Country: Romania
Line Voltage: 230V 50Hz
I'm a: Hobbyist Tech
That called thermistor is an NTC and is wide used in SMPS as inrush current resistor.
On older designs there was a resistor from bridge rectifier to main capacitor,but since even a little value generate some power loss , they switched to NTC.
When cold have some low ohm value to limit inrush current when connected to main voltage then heat up,resistance decrease to almost 0,no voltage drop across NTC,no power loss
gabiz_ro is offline   Reply With Quote
Old 02-03-2022, 03:48 PM   #25
Quantum IC
I replaced the thermistor with a 2.2Ω 7W ceramic resistor because I couldn't find a similar thermistor and just as a test to rule out if the thermistor was faulty.
This resistor also gets very hot in about 1 minute.
I can't figure out why, if when I take the amp reading through the thermistor or through the resistor, I don't get a high draw.
Old 02-03-2022, 04:15 PM   #26
R_J
City & State: ☻
My Country: Canada
That's because a RESISTOR is not a NThermistor. the resistor never changes to 0Ω it is always 2.2Ω and the voltage drop will case heat. Remove the resistor and replace it with a NTC THERMISTOR
R_J is offline   Reply With Quote
Old 02-03-2022, 07:25 PM   #27
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
A thermistor will get hot. Look up temp. specs. on it. It will burn your fingers.
dskall is offline   Reply With Quote
Old 02-04-2022, 05:20 AM   #28
dkneyle
City & State: Tathra, New South Wales
My Country: Australia
Line Voltage: 230VAC 50Hz
I think you're wrong. Of course, 250W is too much, it's even above the consumption marked on the label of this television.
But I got 600~700mA (0.6~0.7A) and if I'm not mistaken that means around 66~77W.
Mi line voltage is 110V.
The label on this TV says a power consumption of 158 W.
It's an LCD TV. Its backlight is by CCFL lamps.
Apologies - you are right about 110VAC - I calculated wrong.
dkneyle is offline   Reply With Quote
Old 02-04-2022, 05:29 AM   #29
dkneyle
CCFL TV will have an inverter circuit. I'd still be looking closely there for a problem.
Old 02-04-2022, 05:50 AM   #30
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
Training manual link
https://www.manualslib.com/products/...50-491425.html
vinceroger69 is offline   Reply With Quote
Old 02-04-2022, 02:54 PM   #31
nomoresonys
My Country: U.S.
Badcaps.net Technical Forums © 2003 - 2022
