Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 12-27-2014, 12:41 PM   #1
Serlynth
City & State: PA
My Country: United States
I'm a: Knowledge Seeker
Default Samsung LN46C60351FXZA No Picture
I have a Samsung LN46C60351FXZA that is about 4 years old. One morning I turned it on and it was working fine. About 10 minutes later, the screen went black, but the audio was still there. The TV powers on and the audio works. I can change the source of the tv and the audio stops until i change it back. There is just no picture. I have opened the TV up and all of the capacitors look fine. Any help would be great.
Serlynth is offline   Reply With Quote
Old 12-27-2014, 12:48 PM   #2
sordids999
sordids999's Avatar
City & State: United Kingdom
My Country: uk
Line Voltage: 240v
I'm a: Hobbyist Tech
Default Re: Samsung LN46C60351FXZA No Picture
Pictures showing your tv parts may help you more with fixing your problem
sordids999 is offline   Reply With Quote
Old 12-27-2014, 01:09 PM   #3
capkid
City & State: Federal Way,WA
Line Voltage: 120VAC 60Hz
Do you see a picture if you shine a flashlight at the screen? Also, are you sure you've correctly noted the model number?
capkid is offline   Reply With Quote
Old 12-27-2014, 01:45 PM   #4
Serlynth
City & State: PA
Yes, it is the correct model number. I dont see anything if i shine a flashlight at the screen. I will try to get a better flashlight to test it too.
Pictures are attached. If needed i can take closer pictures of certain parts as directed.
Old 12-27-2014, 05:39 PM   #5
nomoresonys
City & State: midwest
My Country: U.S.
can you tell if you get a menu at all?
nomoresonys is offline   Reply With Quote
Old 12-27-2014, 06:01 PM   #6
Serlynth
City & State: PA
I am assuming the menu shows up as I can change the source, volume, etc. it's just a black screen.
Old 12-27-2014, 06:34 PM   #7
capkid
The model number is not the same as what you posted in the thread's title. This particular model is known for having PSU/inverter issues. I'd start by checking PSU output voltages. Also, I'll wait for a definitive response as to whether an image is visible when a flashlight is shined at the screen.
Old 12-27-2014, 09:13 PM   #8
Serlynth
City & State: PA
Sorry, it was a type, 5 instead of k!
Also, should i be able to see anything with an iphone flash light, or will i need a heftier one? I will grab a multimeter from work when i go back on Monday.
Old 12-27-2014, 09:38 PM   #9
capkid
And the "0" and "3" were transposed Anyway, an iPhone light should be bright enough.
Old 12-27-2014, 10:46 PM   #10
Serlynth
City & State: PA
Then no, i did not see anything on the screen with a flashlight.
Old 12-28-2014, 02:27 AM   #11
nomoresonys
My Country: U.S.
maybe check the fuse on tcon board.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
