Thread Tools | Display Modes |
#1 |
City & State: NC
My Country: US
I'm a: Knowledge Seeker
![]() I performed the NorCal715 (YouTube) 'freeze' test on both MC201 and MC301 sub-boards on my 2008 plasma's Power Supply board and found that MC201 needs that tiny, surface-mount capacitor replaced.
A frequent poster on that thread claimed to have removed this bad cap and run the TV for weeks without a problem. Eventually, though, he *did* install the new cap (1 uF, 50 volt, electrolytic, non-polarized). I've done some soldering in the past and am generally a very careful person in everything I do, so I *think* I can at least successfully *remove* the existing capacitor without damaging anything. Soldering in the new capacitor is a little trickier, however, because of the extremely small size. So my question is: Is it possible that this cap simply needs to be removed because it has failed internally as a short circuit (possibly allowing DC voltage through)? If I don't really *have* to re-install the new cap, I'd rather not. As I said, the frequent poster on the YouTube thread ran the set without the cap for weeks. Additionally, I came across a reference in another thread that said a Panasonic Tech knew of a Service Bulletin that said the cap simply needed to be removed (but so far, no corroboration of this anywhere else that I can find). Last edited by MajorSkeptic; 09-25-2014 at 03:38 PM.. |
#2 |
City & State: Vologda
My Country: Russia
Line Voltage: 230VAC 50Hz
![]() usually helps TEA1611T replacement on module MC201
#3 |
City & State: NC
My Country: US
![]() OK - It appears I've "fixed" my Panasonic TH-PZ46850U Plasma with the 10-blink problem. I just ended up removing that bad (microscopic) capacitor on MC201 (in place .. I did *not* remove the power supply board). When I powered the set up and it worked, I decided to leave well enough alone.
To get the bad cap out, I first bent the tiny MC201 sub-board on the power supply board to the left until it was perfectly perpendicular with the power supply main board. For some reason, it came from the factory bent about 30 degrees to the right of perpendicular, and with other capacitors nearby, I didn't think I could get the soldering iron in there successfully without damaging something else. Next, I put the TV on the floor standing on its left side. I did this because now the tiny MC201 sub-board would be sitting horizontal (parallel to the floor), which made it easier to work on. Next, I put a dab of solder on the cap's outer-edge connection (don't ask my why, but NorCal did this before removing his cap - maybe it spreads out the heat load from the iron???). Then I put a 90-degree angle pick on the back edge of the tiny bad cap and applied pulling pressure toward me, while also applying the 15-watt soldering iron to the cap to break it free. With the capacitor removed, the set came up and ran fine this past weekend. Why does the set run with the capacitor removed?? Beats me. My guess is the circuit prefers an open connection here and the cap failed closed?? I dunno. Will I eventually install the replacement capacitor? I have it, but I don't think I will install it. WAY too small of a soldering job and I think I'd just end up causing another problem. If the problem comes back, it'll probably be the same capacitor failing on the MC301 board. Then I'll do the freeze test again to confirm, and remove that cap, too! |
#4 |
City & State: NC
My Country: US
![]() Found this explanation in the comments under the NorCal video regarding the function of the bad cap on the MC201 (and MC301) board:
Mike Powers (1 year ago): The cap is a bypass capacitor. I assume the failure mode is toward open and that extra leakage is tanking a supply and causing the error codes. Removing it will fix the problem, but may create others down the road since the IC won't have a nice, stable supply voltage. As shown in the video, the IC is a TEA1611T. |
#5 |
City & State: NC
My Country: US
![]() Just wanted to post an update with my Panasonic TH-46PZ850U plasma (built 2008, put into service April 2009): Had the 10 blinking lights. Set would not come on. Did the "NorCal" YouTube test spraying refrigerant out of upside down can of compressed air on to MC301 then MC201. TV came up when MC201 was frozen. So I removed the *very tiny* capacitor off the MC201 board in October 2014 and did not replace it. The set is still running fine and it's been 5 months now. I *have* the replacement capacitor but don't think I can solder it in correctly due to the extremely tiny size (afraid I'll just end up bridging the two connection points) I did *not* touch the capacitor on MC301 as the "freeze test" showed the problem to be on MC201. I'm sure at some point the set will fail again and MC301 will have to be removed but I'll cross that bridge when we get to it
#6 |
City & State: NC
My Country: US
![]() Another update: 8 months now running the set heavily with no capacitor and running fine. Starting to think this VERY TINY cap is not necessary - the hardware equivalent of dead software logic.
#7 |
City & State: Ontario
My Country: Canada
![]() Hi everyone. I have a 46pz80u and I have the 10 blinking lights. I am thinking about taking the capacitors off. I would like to install new ones but my soldering skills are garbage. Any more opinions out there about just taking the capacitors off and not putting in new ones?
I may just pull the two little boards m201/301 and find a small shop to do the removal and installation of the new caps. Thanks for any replies |
#8 |
City & State: Windsor ON
My Country: Canada
![]() Do as the previous poster did and remove the cap. Break it if you have to (but don't damage the board or traces!) If you have to have the ic replaced at some point then tackle it then.
You may have replaced it with a roll out wallpaper tv by then anyway. |
#9 |
My Country: Canada
![]() Haha thanks. I am a total noob in regards to this repair stuff. I may just do what you mentioned and see what happens. I did see from reading another forum that instead of using a solder iron...this person used tweezers to break off the little capacitor from that little board. I will see what I can do after I take the back cover off and get a better look. Thanks
#10 |
City & State: NC
My Country: US
![]() I'm back! It'll be TWO YEARS next month and the TV is running fine without the capacitor. Take off the back panel, turn the TV on its short side and lean it up against a wall. This positions the tiny board with the bad capacitor horizontally (or parallel to the floor). Then while applying a little pressure to the back side of the tiny capacitor with a pick (small $1 hand tool I bought at Harbor Freight), heat the capacitor with a 15-watt soldering iron until the solder weakens enough to break the cap free.
#11 | |
City & State: NC
My Country: US
![]() Quote:
#12 |
City & State: NC
My Country: US
![]() Well ... it's 2023 and the TV is still running fine without the capacitor! So - we've reach 8.5 years! Yahoo!
And this TV gets very regular use ... so it's not like it's just sitting there doing nothing! I should check the Maintenance screens to see hours of use since purchased new, but I'd bet it's *at least* 10,000 hours! |
#13 |
master hoarder
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
![]() Nice!
![]() Thanks for coming to report back all of these years. Really puts confidence on the repair. Normally, removing components without replacing them is a no-no... but I guess there can always be exceptions, depending on the circuit. At over 8 years with this repair, that TV owes nothing to nobody anymore, LOL. These days, it seems most electronics rarely make it past 5 (or people replace them by then, because they replace them with something newer and "better".) I suppose this also speaks volumes about the quality of Panasonic plasma panels. 8 years with high usage is pretty good, IMO. I've acquired a few old Samsung plasma TVs recently, but wonder if I should keep them or not and how long they would last. I've heard some like to blow the drivers after some time. |
Thread Tools | |
Display Modes | |
