Dell n5010 can be converted from graphic version to non graphic
    Re: Dell n5010 can be converted from graphic version to non graphic
    Hi polytek
    Please find attached image
    After conversion of dell n5010 getting white display and fan is spinning very fast please give me solution for it
      Add the red marked 0 ohm resistor array to solve this problem.
        I have added 0 ohm resistor where is red mark but still in same condition
          it's works perfect for me
            Hi George it's not working for me could you help me to troubleshoot problem
              i had same problem with you (white screen) and soldering again all resistor,capacitor and work with any problem (drivers,bios,heat,boot) my Motherboard is CN-052F31 48.4HH01.011.
                Hi and sorry for my bad english and my noob quastion.
                Please give me a advice, I resolder again all of the parts that I move or add and again black screen. I see that screem diming and ive put hdd and it is booting os but no screen, if I put out the ram I hear 2 beeps which is normal. So were I`m worg, all the parts I added was from another board because in my city and most of the country dont sell so small parts
                p.s. And for last I desolder the ATI chip to see if problem was in him, but same story.
                p.s2. I was using the 4 photo instruction that was translated from chinese.
                p.s3. Maybe I didint traslate corect resonant capacitors what tha mean ? Normal ceramic or some special ?
                Thanks in advance !
                  working like a charm, first try.
                  only extra parts needed are 4 resistor networks, xtal stuff and inductor. rest is on the board (exchange)
                  Intel mobo btw.
                  thanks!
                    not only DELL , but several machine can be modded to disable DSC and use only UMA just a mather of moving 2 resistors usually and lifting core coil .
                    i've done it for many motherboard allready
                      Hi could you please help me to solve my dell n5010 white screen problem after dis to uma conversion
                        The list of those models which we can easlly convert to the uma after removing the graphics supply coil ....
                        Lenovo g500s
                        hp 431
                        dell 5520
                        sony mbx-239
                        lenovo g580
                        hp notebook r53
                        dell 3521
                        dell 411o
                        hp probook p4540
                        lenovo t420,y560,g570,z570
                        hp dm4-3000
                          i treid and succeed on this n5010 succesfully ok
                          no problem
                            no problem
                            please qoute the method that worked for you...becouse there is few different methods in this thread...
                              no problem
                              Please quote the method
                                The 4-photo method works well. Thanks!
                                  Is it applicable on N5110 Motherboard ?
                                    Hi guys plz may help me....
                                    I want to have more laptops graphics conversation chart
                                      But its not working in Dell inspiron 5110.
                                        Dear sir thank u so much for replys
                                          No it is not. You have to follow 4-photo method to get it working
