HP 15 | BDL50 LA-D703P Boardview || Schematic
    As per title I'm looking for a schematic or boardview for this board. Having trouble with the 3.3V & 5V region.
    Got B+ (19.5V)
    No 3.3V
    No 5V
    No heating components, No shorts.
    Also having https://cdn.badcaps-static.com/pdfs/...e4b2fed49c.pdf for upper & lower so a boardview would be really nice.
    while alive { live(toFullest=true) }
    Re: HP 15 | BDL50 LA-D703P Boardview || Schematic
    Never mind, though it would still be nice to get one for future work...
    Problem was with a resistor between B+ voltage and VIN for PU2 (The 3.3V/5V Reg/Buck. The supply was nearly nothing it's supposed to be 4V something in this setup.
    Also the https://cdn.badcaps-static.com/pdfs/...e4b2fed49c.pdf Mosfet was faulty for the 2nd Channel.
    Overall the issue here seems like there were a spill of something sometime in the past.... I only noticed some dark spots around that area on the Caps... Anyways
      I've got this board for the 3'rd time, for 6 month period, and the problem was always related with 3v standby, first time it was ALC3227 RT8243A(3v ch dead) AON7934, second was just RT8243A(3v ch dead), and now again RT8243A(3v ch short), before last time, couple days earlier, after sudden power loss , wi-fi card stop workinkg after power on and lan disappears from dev manager, my guess it is all related with 3.3v supply, but what cause
        BDL50 LA-D703P schematic
          i need bdl50 la-d703p schematic diagram
              https://drive.google.com/open?id=1SK...K_WztET6clNBY8
                thanks king
                Electronicman
                  Can you resent it thanks
                    Hi!
                    Can you share the file?
                    I have no V-Core CPU when starting the machine...
                    Thanks in advance
                      Originally posted by lmg1977 View Post
                      Hi!
                      Thanks in advance
                      Can`t you click on the link ?
                        Chances are it's not the correct file anyway.
                          Inside link file is LA-D704P.
                          Now here schematic.
                          Request Moderator Delete post no 5.
                          Here is link
                          https://www.badcaps.net/forum/showth...light=la-d704p
                            Still the wrong schematics.
                            https://www.badcaps.net/forum/showpo...94&postcount=3
                              Has anyone found the boardview schematics for this?
                                try this
                                  hi dear
                                  im looking for the same boardview in your link but its not working can u please help me to get the boardview for this bdl50 la-d704p rev 1.0 BOARDVIEW
                                    Not available.
                                      Bdl50 la-d703p rev 3.0 boardvİew lazim
                                        anybody have the board view file of the same, pls help
