I've got this Yoga laptop for a reasonable price. Seller said it suddenly turned off. However, he or someone else tried to repair it, making the situation even worse: he told me the NPCE388 has been replaced, but nothing else was done.
Actually, some power supply jumpers have been desoldered. Sadly, all of these rails are shorted to ground.
Before going on, take a look at the motherboard. This is the best quality picture I could find of it:
And this is a particular of my board:
I could not find any schematics of this board over the web. Luckily, I could find many similarities with the Yoga 3 motherboard, whose schematic I attached in this thread (look below).
Thanks to this document I could name the shorted rails, which you can see in the image above in red text.
I tried to supply the board with a constant current generator in order to isolate the short (up to 1A, with about 0.5W dissipated from the board). Sadly, I could not notice any component heating up. Actually, some of them warm up, but not that much, and I don't want to break anything since these boards are quite expensive.
I also tried to desolder the EC since, according to schematics, many rails are going there and previous owner has replaced it, but the result didn't change.
So I am looking for some help to isolate the issue.
What's more, in the nearby of the EC there is a 3A linear regulator (APL5930). By comparing my board to the new one I could state that some of the components (in particular, configuration resistors that sets the output voltage and the output filter capacitor) are missing or misplaced.
A pull-up resistor for the EC is also missing, but I've already placed a new one there.
According to schematics, the two configuration resistors must be 1.54k and 1.74k. I could find the 1.74k in the correct position, but the two in the red circle are 10k (probably the pull-up resistor) and a 2.2k, which doesn't make much sense when calculating output voltage (I would get 0.8*(1+2.2k/1.74k)=1.81V, while with the schematics values, 0.8*(1+1.54k/1.74k)=1.51V). Also there's a 1nF capacitor, while in the schematics is used a 10nF one.
If any with a similar board could measure the resistors and tell me the value will be really helpful. If not, at least please confirm that the generated voltage is 1.5V so that I can put a new 1.54k resistor there.
Thank you
Thank you
