Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > MSI/Microstar
Thread Tools Display Modes
Old 11-03-2017, 07:49 AM   #1
piernov
City & State: Valbonne, 06
My Country: France
I'm a: Knowledge Seeker
Default MSI B75MA-E33 (MS-7808) and W25Q128BV BIOS
This is the second time I need to flash the BIOS on my board and I also had to do it one time on a friend's (same model, same batch since I ordered 2).
My friend's board was acting up and most of the time would boot only after a CMOS reset. After flashing the BIOS everything was working again (except that Windows was crashing but it's probably not related).
In my case, no matter how many CMOS reset I did, it would only boot after several attempts (more than 10 or 20), otherwise it was only showing a black screen and rebooting randomly. After flashing the BIOS, everything was OK.
A while after, the computer was dropped while it was being moved. It was not working anymore and only boot looping before showing anything on the screen. After plugging in a POST diagnostic card, I pinpointed the problem to the RAM, it was rebooting at POST code 55 (RAM not detected) or shortly after (related to RAM). I obviously tried different sticks and none worked. I reflowed all the RAM slot solder joints, and it booted again.
Today, after a blackout, the computer did not boot (same symptoms as when I had to flash the BIOS). Last week I had a few cases where it didn't boot the first time, and before the blackout it had been running for 3 days. However it had me really confused because the POST card was showing code 32 most of the times (related to RAM) so I thought I had another RAM issue. And after trying a few different sticks it booted… Well, it was only a coincidence because after shutting it down, it didn't want to boot again. After several attemps, I was finally able to get in the BIOS. I made a dump of the current BIOS, and, strangely enough, it was getting really slow after 32% (coincidence again…). I downloaded the exact same version (1.7) and the MD5 didn't match, but that's not relevant since the downloaded file isn't a full raw dump apparently. I flashed it, and it was back in working order. I tried to dump the BIOS again and this time it went very smoothly.
I don't know why the BIOS ROM would fail, but it does. I don't know if it's a board issue or a SPI ROM issue, but now whenever I see one of those I'll remember this case and try to flash the BIOS.
TL;DR: watch out for BIOS corruptions on this board or this chip, it happens.
__________________
OpenBoardview — http://openboardview.org | IRC — #openboardview@irc.freenode.net
piernov is offline   Reply With Quote
Old 11-23-2017, 07:06 AM   #2
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
I'm a: Professional Tech
Default Re: MSI B75MA-E33 (MS-7808) and W25Q128BV BIOS
could be a bad spi flash.
try a new one
kc8adu is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
