Hello, Just received Sony Audio System Shake 7 , the customer said it went dead since after thunderstorm . I need help.
Sony Audio System Shake 7 Went dead after thunderstorm
Re: Sony Audio System Shake 7 Went dead after thunderstorm
Start with the power supply. Does the stand-by section output the proper voltage? If yes, can you turn-on the main PSU without the amp being connected? If not, does the APFC try to run when you turn on the main PSU?
More clear and up-close shots of the power supply board would be helpful.
