HDDs shutting down at 2/3 of the surface when writing on them?
    I have been lately experiencing this issue in way too many cases which makes me think this is some kind of new failure mode. Basically especially large-size drives (2+ TB, but also seen that for 250GB 2.5" drive too) read the whole surface fine, but when writing to it, at aprox. 2/3 the surface, likely after reaching a particular sector, they just shut down. After power cycling them they appear to work fine, but the same happens if I write to them again.
    Cuting the rotten space off by partition and using only the first 2/3rds of the total capacity appears to work.
    So what the heck is this?
    Re: HDDs shutting down at 2/3 of the surface when writing on them?
    Sounds like a bad board or a bad head connection. Maybe a bad head amp.
    And HDDs usually don't power down by themselves, in the case of giving up on a sector, likely a click-of-death that can only be heard with an ear up real close...
    I had a Maxtor "slimeline" model give a quiet click-of-death before, probably when one of those little bastards failed at SpinRite, IIRC.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    16 GB AData XPG Spectrix D41
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
      sounds like whatever supplies current to the head is overheating or has a bad connection either directly or upstream.
      a test,
      write to 25% of the surface,
      wait 5 mins
      write to the next 25%
      repeat until it's complete - or resets.
      btw, what drives are they??
        a test,
        wait 5 mins
        Simpler test: write to the LAST block, first, then move towards the START of the volume. If it still fails at "2/3 progress", then you know you're at a different LBA than when writing front to back. (this aims to disprove any surface defects causing the problem)
        If the only tool you have is something like dd(1), then make a note of what block number it fails at, each time. Then, try increasing the block size (not to change the "block number" but, rather, to reduce the overhead, per transfer, in the hope of getting further into the drive in a given amount of time.
        dd if=/dev/zero of=/dev/<whateveryourOSnamesyourdrive> bs=1024K
        vs.
        You can also try creating TWO partitions on the drive and see if you can write each completely -- though one at a time.
          does the controller/drivers support +2TB drives? Something in my memory is telling me there is an issue with certain certain older stuff and +2TB drives
            If the BIOS didn't support the size of HDD, then you simply would get a sector-not-found error in DOS or its ilk. (until you shrunk the LBA, which can be done by setting the HPA)
            Or an error of a bad block in the event log, in NT-based Windows. Or simply an error being reported while attempting to write or read past a certain point in Windows.
            Or an OS crash.
              Been using HD Tune, with one of the drives I actually thought it is good and put it in my IBM server (NAS) I just started writing ton of movies onto it.
              Most of the bad drives were some 3TB Barracudas tested under Vista on SB710 southbridge. Since they have already been ditched by corporate as bad, the problem is definitelly in the drives. Tha last one, WD2500BEVT, also suggests it is nothing with capacity.
              With what can I start writing from the end? Everything I know always starts from the beginning.
                get a Linux live disk and read up on the DD command.
                or type "man dd" for the onscreen manual
                and remove the pcb's and check the pads for tarnish.
                  Most likely pulled from a shelf where they have been spinning, nonstop, for 3 or more years. Look at the SMART data before even attempting to use! Note that many companies just retire systems after a certain number of calendar months without actually considering how much "useful life" they may have remaining. caveat emptor
                  YOU probably can't. I write little programs to seek to specific spots on the "raw" device, write, seek to next, etc.
                  OTOH, you could split the drive into two (or more) partitions and verifying that the entire surface can be accessed -- by scrubbing each partition, separately.
                    Tried scratching it a bit when moving PCBs around. It seems that the drives are HW calibrated for some time now and require re-doing it, or transfering the EEPROM with the data to the other board.
                    Must have some different corporates there, lol. These have been in RAID array, all of them have quite high runtime. I could try testing it the partition way I guess, especially the small WD one which I still have here, and also it is small enough so it won't take half a day
                      [retiring shelfs after a few years of uptime]
                      I've often encountered boxes full of identical drives and discovered they all had PoHrs of 43502, 43513, 43508, 43507, etc. Or, 34788, 34792, 34777, etc. So, you know they likely came out of the same device (or set of devices).
                      If you assume they are left spinning 24/7/365 (disk farm), then that's ~5 years (or 4 years for the 30K's) of continuous uptime.
                      I take a peak at the number of remapped sectors and, if not 0, consider the drive as scrap.
                        No joy, shuts down in the very same manner. It also couldn't be anything like that mysterious supermagnetism as this bloody 250gig 2.5" drive is way too old with too low capacity per square unit (unlike the 3TB drives). I think that they just started screwing up big time, after only 30 years of making hard drives. What other explanation there could be? What could be so bad on the surface that it makes the electronics go crazy and shut down instead of just marking the area bad and reallocating the sectors?
                          I don't think that a "bad surface" makes the HDD spin down. That one would be the first doing that. In extreme cases the platter looked like one had sanded it and fine metal particles inside the HDD while opening. So the HDD had actually seized because of the fine metal dust.
                          What you are describing is different. I don't think it is anything mechanical either, because it takes quite a bit of force to make the HDD stop spinning. Never the less, I wouldn't trust that HDD and throw it out.
                            No, but the head assembly may be encountering some problem trying to extend across the media to that point.
                            Regardless, its trivial to TEST if this is indeed the case -- and not a consequence of run-time, etc. -- just by deliberately positioning at that place (vicinity) at the START of your test (instead of waiting a long time to get to that place "eventually")
                              No, but the head assembly may be encountering some problem trying to extend across the media to that point.)
                              Even if that is the case I don't believe the HDD will spin down for that either. It just wouldn't read and the heads go back and forth.
                                Do you really think the controller (in the disk) will sit there tweaking the head assembly (in and out) FOREVER without taking some sort of action?
                                (I may drag out a discardable disk to test this -- pull the covers off and cram a Q-tip in the head assembly to prevent it from moving beyond a certain point just to see what it does...)
                                  clicky-click - yes, most drives will just seek forever!!
                                  only drives intended for raids will quit and send a fail message instantly.
                                    Did you read the thread before posting this, at all?
                                      Yes.
                                      Note that "reaching a particular sector" doesn't have to mean that there is a surface defect. Rather, it can mean that the software is processing a certain LBA number (and has a bug). Or, the head assembly is being tasked with displacing a certain amount INTO the surface. Or, ...?
                                      If you're always "getting there" from the start of the volume, then a certain amount of elapsed time (at high duty cycle) has passed.
                                      [I had a DSL modem that would drop connections after a fixed amount of traffic -- regardless of the nature of the traffic. An internal counter would overflow and it would drop the connection. Try again. And again. And again. Nope!]
                                      To remove the apparent physical configuration of the drive at the time of failure (that "spot") from the equation, you need a way to seek to that point WITHOUT having to "start from 0" each time (to rule out a duty-cycle related problem).
                                      If, instead, you started your test in that general vicinity, then a problem with that "spot" on the media (whether it is surface, head assembly or whatever) should manifest VERY QUICKLY! If, instead, the process continues to a point that is obviously BEYOND the original hangup location, then you can rule out that part of the surface and the other related electronic and mechanical aspects of accessing that "spot" -- cuz you were able to do so by starting from a different location/offset!
                                      E.g., assume there are 100 sectors on the volume and that it's crapping out at sector #66. If you cut the drive into two partitions -- [0,49] and [50,99] -- then you would expect to be able to wipe the first partition non-stop, all day long (i.e., not thermal related, either!)... IF the problem was related to "66" in some way (electrically, mechanically, software, etc.)
                                      OTOH, if you tried to wipe the second partition, you would expect the failure to manifest VERY QUICKLY... after just "~16" sectors. But, if the process continues to completion for the entire second partition -- [50,99] -- then it's hard to argue that there is something physically/electrically/mechanically wrong with "66"!
                                      I see nothing in the thread to suggest that you've tried "skipping the first half of the volume" (in my example). Rather, you've assumed that skipping the last THIRD of the volume "fixes" the problem:
                                      This doesn't eliminate "66" from the list of possible causes. OTOH, if you repartition the drive with the values I suggested (by way of example), then you should be able to endlessly write the first (non-66) partition OR the last partition without any problem IF it is unrelated to "66".
                                        Guess you must have ACCIDENTALLY missed posts #10 and #12.
