Acer AL1916W
    Re: Acer AL1916W
    Also, what are the part numbers of
    IC201 and IC202 (top side)
    U101 and probably U102 (the other legged IC on the bottom side)
    edit: And measure the resistance of the inverter transformer pins S1 to S2 and S3 to S4 (in circuit - power OFF and LCD unplugged) as per
    http://lcdparts.net/TransformerDetai...ProductID=3360
    Both should read around 650 ohms.
    --- begin sig file ---
    --- end sig file ---
      Re: Acer AL1916W
      Originally posted by mscott03 View Post
      The dark green caps are Taicon.
      I just finished replacing all the bad caps since I got the new ones today and still no power to the lights. LCD works, image shows up, green power light comes on, just no juice to the lights..
      on the back side of the board,Is f200 good?
      Al.
        Re: Acer AL1916W
        IC201 and 202 have this p/n:
        P605
        BZ6G1S
        U101 and 102 have this p/n:
        B U3
        PC817
        As for measuring resistance of the S1 - S2, and S3 - S4.. How do I know which contacts those are? Mine are not labeled, not sure if they normally are.
        F200 looks fine, but I am not sure what a bad one looks like, doesnt seem to have any damamge to it though.
          Re: Acer AL1916W
          Edit: Replied too soon before visiting the site! I see which contacts those are -
            Re: Acer AL1916W
            S1 - S4 are the outside pins of the transformers.
            To measure a fuse, put your multimeter on ohms (probably 200 ohms). Put black on one side, red on the other side of F200.
            A good fuse should read 0.3 ohms. If it reads "1" or 0L, it is an open fuse (blown).
            edit: BTW, that is a good catch on finding F200. I never expected to see a fuse on the bottom side on a board. Normally they are on the front side.
              Re: Acer AL1916W
              Meter reads .764k ohm on first and .761k ohm on second....
                Re: Acer AL1916W
                Are you talking about the transformer? If yes, the transformer is likely good. This test doesn't catch a shorted turn on the transformer, but let's assume it is good for now.
                  Re: Acer AL1916W
                  There was a explanation given for manufactures using the small surface mount fuses. To keep the everyday user from thinking if 2a is good then 4a must be better, I think it was plainBill.
                  A lot of the delta boards use them .F200 is important to check because it supplies power to the back light controller.
                  Al.
                  Last edited by alexanna; 09-01-2010, 03:58 PM. Reason: i cat figure out how to quotew
                    Re: Acer AL1916W
                    Al.
                    Still a great catch on spotting F200. I would have looked on the front side PCB forever.
                    Also for all the newbies and first time posters, this is a good example why clear focused pictures are required. If this were some fuzzy, out of focus, 800x600 pic, we (Al) would have never spotted this fuse.
                      Re: Acer AL1916W
                      You guys are awesome! When I test the F200 fuse should I have it off the board, or will it test properly still soldered on?
                        Re: Acer AL1916W
                        In circuit is fine.
                        edit: report actual ohm reading
                        Last edited by retiredcaps; 09-01-2010, 07:52 PM. Reason: edit: report actual ohm reading
                          Re: Acer AL1916W
                          When I test one direction I get 0L, and the other way continuously climbs from 2.4k Ohm up. Blown fuse? I will replace it tomorrow morning after checking back later with you all.
                            Re: Acer AL1916W
                            Yes, blown. It should read 0.3 ohms. If that is the root cause, you can give a big thanks to alexanna. There is no way, I would have seen that fuse. I will remember to look for that in the future though.
                              Re: Acer AL1916W
                              I replaced the fuse and noticed something in the right direction, now when it powers up the lights flash or flicker for a second then shut off..
                                Re: Acer AL1916W
                                You might want to check IC201 and IC202 for shorts. Apparently, this board is prone to one of those chips failing. Replace them in pairs. Part number is AOP605 and available from digikey for under $1.00 each.
                                  Re: Acer AL1916W
                                  Dose the fuse remain good,After the flash?
                                  Al
                                    Re: Acer AL1916W
                                    Agreed.
                                    You can test for shorted transistors "in circuit" (with power off and unplugged)
                                    a) put black probe (com) on pin 1 and red probe on pin 2 - read ohm
                                    b) put black probe (com) on pin 1 and red probe on pin 3 - read ohm
                                    c) put black probe (com) on pin 2 and red probe on pin 3 - read ohm
                                    If any ohm reading is less than 40 ohm you probably have a shorted transistor and it will need to be replaced. Test it out of circuit to verify.
                                      Re: Acer AL1916W
                                      Agreed.
                                      the aop605 is in a dip -8 package I have not looked at data sheet but testing is going to be different.
                                      Al.
                                        Re: Acer AL1916W
                                        Al.
                                        Too much sun today.
                                        You are correct. I'm getting my threads all mixed up (have 7 tabs open right now). Ignore my previous instructions.
                                        edits below:
                                        Datasheet at
                                        Test S1-G1, S1-D1, G1-D1. Note there are 2 D1s.
                                        Test S2-G2, S2-D2, G2-D2. Note there are 2 D2s.
                                        If my math is right at 12:30am, that should be 12 readings.
                                          Re: Acer AL1916W
                                          I knew i would wake you back up. have a good morning.
                                          Al.
