Zener T3D98 data required
    I am trying to repair a Panasonic plasma 42 inch TV TH-P42C10D. one of the suspicious components is a Zener T3D98 which is showing infinite resistance on both sides using a diode check with a multimeter.
    I cannot find any data on this. I presume this is a high voltage 100, 150 or 200 volts zener in the power supply after the bridge rectifier and parallel to the transformer input.
    How can I get data on this and can it be checked with a DMM?
    Thanks.
    Re: Zener T3D98 data required
    Very unlikely a zener or diode will go open
    Check again on diode setting on your multimeter
      Thanks. I have desoldered and checked it is open on both sides. I want to know if they have higher threshold voltage and therefore it does not show on the dmm I am using.
      I would also like to know what should be the voltage of a zener being used accross the bridge rectifier and trasnsformer of the smps?
        That T3D98 has two diodes connected common anode, one is a zener one is a regular diode. It will measure open circuit
          Originally posted by r_j View Post
          that t3d98 has two diodes connected common anode, one is a zener one is a regular diode. It will measure open circuit
          +1
            example .....
              The questions are:
              1) What is not working?
              2) What power supply section that this snubber diode is located in?
              3) Pictures of what we are dealing with?
                Thanks, that is why it is showing open on the dmm diode check. I will have to look at the power supply section of this tv again.
