Hi there.
I got a Ideapad U430p it has issues to come up. No Screen (but I think the Backlight comes on [with some bios]).
The described problem is: The Notebook only starts if you power on/off the notebook multiple times. - I know this issue from some Edge 13 in the past (but never solved it) I haven't got the notebook turning on since I have it.
All Powerrails seem to be up an working. (currently Testing).
Power On button works, Fan spins for a moment. Idle power consumption is 0.005a. While running (no fan spin): 0.292a (no display attached)
replaced the bios and checked the dump. seems the dump is corrupted as well
parseFile: invalid data checksum 47h, should be 43h
parseSection: decompression failed with error "Customized compression failed"
parseVolume: unknown file system FFF12B8D-7696-4C8B-A985-2747075B4F50
some random bios only shows:
Do you have any Ideas what to check?
If I attach speakers and plug in power an start (slow) it's always as described above.
If I turn on PSU and than hit the Power Button I sometimes get some kind of beepings. Not sure how to categorize them. As said, ONLY if I'm very quick.
Of course no beep coded without ram or image with external display.
