Pioneer VSX-1022-K won't turn on
    Re: Pioneer VSX-1022-K won't turn on
    Originally posted by tibimakai View Post
    There are some functions to clear different errors, but only one did something. Not sure what though.
    It is for clearing DC error, pushing these two buttons Advanced Surround + Standby, I'm getting the setup microphone(MCACC) light to turn on and then off.
    I don't even have the standby light on, so I can't do much from these things from the service menu.
    I found the MCACC LED on P126, LED701. For the LED to be turned on, Q701 needs to be on. Q701 is turned on by pin1 on IC701.
    For this to happen, IC701 needs to be powered with 3.3v.
    The 3.3v is controlled by STBY_RLY via Q703, Q702.
    Check STBY_RLY again.
      I will check those. It's to late now.
      I was wondering, we are getting the push button signal at the CPU? Maybe we should check that to be sure.
      Yes, that is KEY1.
        Originally posted by rievax_60 View Post
        All three Key lines should be 3.3v while no buttons are being pressed, pins 90,91,92.
        They all have 3.294V.
        When I press the power on button, the Key #1(pin #90) drops to 0V.
        That seems fine.
        Tomorrow, I will check the other suggested point.
        I'm back to this, since with the Yamaha I don't have any luck.
          STBY_RLY is the same. goes from 004V to 0.06V when the Power on button is depressed.
            I have checked the schematic many times. For the MCACC LED to light up, STBY_RLY must be going high.
            Can someone else confirm this also?
              I see a reset pin at the CPU's #12 pin(looking at the block diagram), what that does and how can be done?
                The reset pin should momentarily pulse low or be momentarily held low when the mains is first applied. Its only function is to cause the micro to start executing code cleanly.
                Im still puzzled how the MCACC LED can light up without STBY_RLY pulsing high.
                  The LED doesn't turn on at all, only when I do the reset. Even then only for a couple of seconds.
                  The receiver is NOT in standby mode.
                  Maybe I should measure then the voltage at the STBY_RLY.
                  I'm looking at the service manual at the diagnostic charts(page #32) and there it mentions that at the connector CN9501(12V for the HDMI board) is not there, then check the cable between the HDMI board and main board. If that checks out OK then check the main board. Why the main board and not the CPU?
                    I think the fault charts assume the receiver has turned on but doesnt actually say so.
                    If a rail originates from the large mains transformer, there cant be any voltage while the receiver is stuck in standby.
                    Yes, check STBY_RLY while the LED is on,
                      Do you suspect the CPU to have an issue and that is why is not booting up the main transformer?
                      I have found a 822-k on Ebay which has some missing components for very cheap. In the SM, it is mentioned that the CPU boards in these three units are the same, only the part number is different.(VSX-42, VSX-1022k, VSX-822-k)
                      "7028071681030-IL, 7028071681050-IL and 7028071681010-IL are different in part number,
                      they consist of the same components."
                        I have measured it and it shows 3.11V for those couple of seconds.
                          You need to figure out why the relay isnt being turned on in those seconds.
                            Maybe some kind of protection is on, but how we can find out which one is tripping the shut down?
                            I will look again at the amp section.
                            The standy light shouldn't be on no matter what ? The CPU controls the standy also.
                            The standby should be on as I plug in the receiver. Even this basic function is controlled by the CPU?
                              Does the 3.11v get to R319 on P128?
                                Not sure where is that P128?
                                R319 is at pin #55.
                                  Its on page 128 in the PDF.
                                    I'm getting the same 0.002V increase, like at the CPU, when it's powered up.
                                      It seems that STBY_RLY is getting to the FRONT ASSY. From there its supposed to leave from CP701 to the STBY ASSY.
                                        Where did you measure this exactly?
                                          At pin #37 of the CPU.
                                          I haven't tried measuring at R319 while I reset the receiver. I will do that today.
