Asus X401A, crazy touchpad...and I now know why
    Re: Asus X401A, crazy touchpad...and I now know why
    please, have somebody schematic for this laptop? have short in memory power rail and need to locate it.
      Well i'm back, six years later. With another X401a, given to me by somebody else. A touchpad working the same way again.
      I now have more power adapters. Still the same, damn, thing.
      I can keep one finger on the touchpad completly still, and the cursor starts shaking around 2-3mm from the point
      I unplug the adapter and go on battery...works fine. Back in...starts shaking.
      Is it, just he power in the house? It was built in 2000. Wiring well grounded. No other problems with ANY other laptops or PC's i've worked on in this house
      I'm just, going insane again. Guess i'll take this to someones houes and it will work perfectly.
      can ANYONE explain this?
        You have the last version of bios?
        And, you have installed the driver for touchpad, from asus support website?
        From my experience, this 2 points have to be accomplished if you have problem with perfect functionality of your touchpad.
          This one is installed with windows 10. Last one was windows 7. There is no 8/10 driver from the asus site. Though it is synapitics so i'll probably try that one next.
          Still. Works fine on battery.
            Originally posted by dj_ricoh View Post
            because that old adapter got a better quality components inside then the new adapter. 100%
            I've tried three different adapters. One is 180W high quality
              Oh I just opened up the bag of laptops he gave me and there is a PINK x401a. Are we going three for three? Stay tuned find out
                Well the pink one has a screen cracked to hell. But I was able to see the right side of it, and, yeah. Mouse shivering on this one too
                Also my sister gave me a bag with most of the original adapters for these.
                The original asus power adapter does the same thing on both
                So does a 180w HP for a much larger laptop
                A stupid rocketfish bb 95w adapter
                A targus 95w adapter
                You guys have no idea how ridiculous this is getting
                  That model laptop perhaps doesn't have as good a filtering as it could and your electricity isn't as clean as it could be.
                    you would think, right? I've repaired many laptops from gaming to 11" netbooks with nothing randomly acting up. As well as our electronics, rokus, tv's, pretty much everything else
                      That laptop and your electricity. 3 identical laptops and it only does it at your house.
                        I just hooked it to my UPS and it still did it. Shouldn't a UPS even plugged in clean the power up some?
                          Can be grounding/earthing issue.
                            Just another guess.
                            Do you have that sticker in place, that i surrounded with red?
                            And, can you please be sure that sticker make good contact where green arrow point.
                            Good luck.
                              this is a very common problem with Dells
                                I am going to sell the pink one for cheap (with a mouse so she can use it without the messed up touchpad). Upgraded the cpu to a 2020m (had lying around from upgrading my mothers top to an ivy bridge i5). It's almost the highest this chipset can take (2030 is the highest). Got a cheap silicon power ssd (with decent ratings). Win 10. Runs great
                                Problem. The keyboard is messed up. Its melded to the palmrest. Found a video that shows how at attach a new one. Better and cheaper than getting a new palm rest from china. Anyone ever done this before?
                                https://youtu.be/j3XWwEwW-cg
                                  Ive done quite a few,you will need to use a good fume extractor and some good ventilation, its a stinky job
                                    is it carcinogenic?
                                    I see I have to use my iron, I'm guessing on a pretty low tempeture
                                    I don't have a rework blower, but I have a heat gun, so low setting?
                                      is it carcinogenic?
                                      All you need is an iron on low setting .
                                        He had to heat the back adhesive cover to get it to pull off
                                          Well I did it and it was fairly successful. When I get the lid fully down, it doesn't boot. When it's loose, it does.
                                          the sticker C.daniel mentioned above is hardly staying on. I'm guessing something is shorting. I got a little adhesive and it's keeping over that loose space
                                          One thing mentioned above is that sticker being responsible for the touchpad issues. Well, I would say maybe except we forget one thing. It ONLY does it when the power is plugged in. On battery, the touchpad acts like it should. I might have traced a possibility, but have no way of fixing it, or even tracing down the specifics of the problem. Again, it does it ONLY when it's plugged in...
