Re: need Help finding replacment Caps
Don't go randomly sticking the probe around that board!
Parts of it are AC and/or on line voltage.
What series is that 4700uF Chemicon? [Big brown one with the shield logo.]
If it's KZG series those will fail like OST [with no bloating] and like OST higher temps [like in a Power Supply] increases the failure rate big time.
The only other Chemicon with problems is KZJ but they aren't brown.
A multimeter will only tell you a cap is shorted, partially shorted, or a dead open to DC voltage.
When you check, the ohm reading may jump around a little and then it should go very high as the battery in the meter charges the cap. [No specific Ohm value just very high as in more than 20 kOhms, more is better.] Then reverse the leads, you should see the same thing again as the cap discharges and then charges in the reverse direction.
If it doesn't charge [go to high ohms] on both directions or if it stays low the cap is shorted or partially shorted.
If it reads high in both directions *WITH NO Charge/Discharge activity when you reverse leads* it may be open.
An ESR meter will tell you how it responds to AC voltage. [Usually at 100 kHz.]
Caps -should- block DC and pass AC.
A cap can be good on DC but not on AC and vice versa which is where ESR meters come in.
- BUT, if you don't do this often it's probably not worth the $75 or so for an ESR meter.
- Most 'occasional cappers' just identify the cRap brands and replace them along with any bloated ones.
A visual inspection might not be enough to spot bad joints on the transformers.
The solder can be where it's supposed to be but there is no bond to the lead because the lead didn't get up to temperature in the automatic soldering process.
- As in the lead is encased in the solder but not bonded to it.
In real bad cases the solder basically forms a tube around the lead and the lead will actually be able to move around. See pic.
Just heating the joint until the solder is nice and shinny usually fixes it.
Sometimes a dab of fresh solder helps.
