acer laptop turn off after 30 min
    My acer board turn off after 30 min fan is ok thermal compound is already done.
    looking at teh scheamtic diagram at the CPU THERMAL TRIP PAGE, 10 can I remove the transistor? i dont have any part to be replace the MMBT3904-7-F transistor..
    need some help please
    Re: acer laptop turn off after 30 min
    First try cleaning the me-region of your bios.
      how can i celan it sir? by flashing a new bios?
        If you want to try and clean the ME yourself here`s everything you need.
        https://www.badcaps.net/forum/showthread.php?t=88533
          If you dont know how to do it then post your bios dump here. Someone will clean the me region for you.
            Sir Im just using a ch341a usb programmer it doesnt support GD25B64BSIG chip, what usb programmer are you using to support this kind of chip?
              I use RT809F
                spi is just spi. flash it
                  If ME Clearing procedure not help you then INtel HM chipset must be changed.
                    I use RT809F
                    those the RT809F supports all latest bios chip also?
                      ohw if that happens i think Ill spend to much
                        Yes, RT809F supports all chips so far i've faced. I still beleive its me-region issue.
                          thanks sir ill try to buy a new eeprom programmer
                            u did not try your ch341a programmer. how u know it cannot flash it?
                            if it is 1.8V chip, just use 1.8V adapter
