HP Elitebook X360 1030 G3 remove password BIOS.
    Password removal option for those who do not have a method through HPUnlocker.
    This option saves all information in the BIOS (serial number, Windows key, etc.) and also excludes the appearance of BIOS notifications at startup (hp endpoint security controller problem).
    1. Read BIOS (32MB) and EC (16MB) firmware.
    Be sure to make backups.
    2. EC:
    2.1) Copy the area from the original and paste into a clean "EC (16MB) Clean".
    Region start - 0, length - DA3000
    2.2) Find in "EC (16MB) Clean" and clear the NvramActiveRegn areas (replace with FF). Save.
    1 area: Start - 37000, Length - 1000
    Area 2: Beginning - 38000, Length - 1000
    3. BIOS:
    3.1) Copy the area from the original to a clean "BIOS (32MB) Clean and Configured" and save as a new file. (Example: "BIOS (32MB) with TAGS")
    Start - 1AF6000, length - 50000
    3.2) In "BIOS (32MB) with TAGS" find the UserCred area (HEX: 55 00 73 00 65 00 72 00 43 00 72 00 65 00 64) and clear (replace with 00) to AdminPW (clear AdminPW too).
    4. BIOS and EC entry:
    4.1) BIOS entry - "BIOS (32MB) Clean and Configured" and EC - modified "EC (16MB) Clean", enable and wait for the BIOS update to complete (before the system boots).
    4.2) Overwriting the BIOS flash drive - "BIOS (32MB) with TAGS", just wait until the BIOS update is complete.
    Reboot and check the result
    Re: HP Elitebook X360 1030 G3 remove password BIOS.
    Hi Alex, slava ukraini. I am not sure why nobody is not thanking you for this post, but here is my appreciation. I have been looking forward for this all around the net.
    Is there a change you know where the BIOS structure is defined for i.e. HP? I would like to understand the structure and be able to find areas of interest (i.e. UserCred, AdminPW etc.).
      Well, it's standard UEFI definition... Thanks anyways.
        I dont understand what I need to do with the files?
          What problem do you have ??
            Re: RCUnlocker
            please help me, remove bios password HP Elitebook X360 1030 G3
              Re: RCUnlocker
              I used the HPUnlocker tool and it works, thank you very much
                HP EliteBook x360 1030 G3
                hello can someone help me to unlock bios HP EliteBook x360 1030 G3 bios
                  Re: HP EliteBook x360 1030 G3
                  Using RC unlocker for 16MB file.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    there is 2 file 32 mb and 16 mb should i use the 16 mb ? to unlock
                      Use 16mb
                        Worked thx bro
                          Hey friends,kindly remove for me Hp endpoint controller error HP 1030 G3 DA0Y0PMBAF0 REV F
                            If you know how to use a hex editor post #1 has all the details to fix the issue
                              2. EC:
                              3. BIOS:
                              Working perfect Alexraspberry
                                Device MX25L25673G
                                  Originally posted by tehmatix View Post
                                  Device MX25L25673G
                                  Please read the updated rules. You must post the laptop serial number. Read some of the other posts in this thread for suggestions,or try RCUnlocker
                                  RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                                  https://www.badcaps.net/forum/troubl...sting?t=103570
                                  You MUST:
