La-b162p
    Re: La-b162p
    Originally posted by jagadish View Post
    ec bios file
    Thank you very much
      Re: La-b162p
      thanks
        Re: La-b162p
        thanks let's see if it will work my device
          Re: La-b162p
          thanks bro
            Re: La-b162p
            Thank
              Re: La-b162p
              Originally posted by ridamouh159 View Post
              Here is
              This zip file contains 2 bin files, how do I program them with the ch314a? Writing only that of 8mb the card restarts.
                Re: La-b162p
                yes with the CH341A programmer you can only write the 8 MB bios ... but first make a backup copy of the original laptop bios ..
                  Re: La-b162p
                  Here is
                  Hi, I flashed the bios with the ch314ea programmer.
                  but the EC file how should you flash it?
                  thank's
                    Re: La-b162p
                    thank's
                    https://ioprogrammer.com/
                      Re: La-b162p
                      thank's
                      Here is my bios
                        Re: La-b162p
                        Can you link me to buy an ec chip for my card?
                          Re: La-b162p
                          thank's
                          You can use the ch341a, but its slow,and tricky too as you have to solder individual wires to the keyboard connector pins.
                          Use NeoProgrammer software - https://www.badcaps.net/forum/showpo...50&postcount=5
                          Flash Ene kb9012 Sio Using Ch341A https://www.youtube.com/watch?v=GQGH6yZuXCc
                          Recommended to modify the ch341a voltage first if you have the black pcb version
                          CH341A volt mod https://www.youtube.com/watch?v=HwnzzF645hA
                          CH341A volt mod https://www.chucknemeth.com/usb-devi.../3v-ch341a-mod
                          You can also buy pre-programmed chips from ebay and aliexpress.
                          If you want to buy an IO programmer there`s other models besides the one that @peste posted theres SVOD3, Vertyanov JIG, RT809F (with peb1 adapter board,but limited to only kb90xx) ,RT809H with adapter board.
                            Re: La-b162p
                            you don't have to buy a chip..program the one on the motherboard..are you sure that the EC bios is corrupt ??
                              Re: La-b162p
                              thanks
                                Re: La-b162p
                                Need help. Tried to downgrade my BIOS and it got corrupted.
                                I have tried to flash bios with
                                the attachment above "Acer Aspire E5-571G- Z5WAH LA-B162P REV1.0.rar (3.72 MB, 3035 views)"
                                still showing black screen.
                                Thanks !
                                  Re: La-b162p
                                  Thanks !
                                  post the original bios of the laptop so corrupt.
                                    Re: La-b162p
                                    thanks ridamouh159
                                    its work
                                      Re: La-b162p
                                      thanks
                                        Re: La-b162p
                                        thank you
                                          Re: La-b162p
                                          Here is
                                          Thanks, it works for me too
