Nt950xdy-a31as bios
    Nt950xdy-a31as bios
    I need help finding a working bios for this computer.
    The laptop model on the title is a Samsung Galaxy Book with i3 11th gen.
    When powered on, keyboard lights up and the fan spins at full speed but and nothing else happens. No-post and no picture.
    I have dumped the current bios with CH341A and also found a replacement BIOS with the help of this guide: https://www.badcaps.net/forum/showthread.php?t=88206
    Also I have read the guide and I have tried the followings:
    * Flash the new bios by making it the appropriate size. (The symptoms slightly changed but still no-post)
    * Combine some of the bios region of the new file to the old one. (Again, symptoms changed such as power cycling forever, but still no-post.)
    Thank you in advance.
    Re: Nt950xdy-a31as bios
    For the past two days I have been trying to flash self-patched ROMs with no luck.
    More information:
    Bottom cover has also this code ( I assume it is the part number of the cover): BA98-03045A10
    Model number: NT950XDY-A31AS
    S/N: 522L9FDR400010Y
      Unfortunately there is no bios for this model on the Samsung homepage to be able to patch your bios.
      Become a Badcaps supporter
      Thanks to all supporters.
        Ah, thank you for checking it though!
          More information:
          Try this one .
            You won`t find bios updates at the samsung homepage, see the link at post #1
              Originally posted by SMDFlea View Post
              Try this one .
              I have flashed it and then read it to check the checksum and they match.
              But now, when I press the power button it(resembles power cutting out) cuts out. No more keyboard light or power light.
              I have waited 15 minutes, just in case the cleaned ME region is being initialized(?). For good measure, I will wait 15 more minutes and if anything changes I will report it here.
              For now it seems that its not working.
              Whatever the outcome is, thank you very much for taking your time to help me out. I appreciate it.
