Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > Custom Tweaks, Modifications, and Revisions
Thread Tools Display Modes
Old 12-08-2018, 10:53 PM   #461
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Re: The ghetto mod thread
Fun with hot melt glue...
eccerr0r is online now   Reply With Quote
Old 12-09-2018, 06:28 PM   #462
Drack
Yup it's me
Drack's Avatar
City & State: Carabobo
My Country: Venezuela
Line Voltage: 110v 60hz
Yes lol, at least is not dangerous, just ugly...
Drack is offline   Reply With Quote
Old 12-09-2018, 07:05 PM   #463
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
ugly is in the eye of the beholder, hot melt glue is a staple of ghetto!
Old 12-11-2018, 12:25 AM   #464
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Quote:
Originally Posted by Drack View Post
https://www.badcaps.net/forum/attach...1&d=1544304317
in reality you cant actually see the foam unless you get very close
This actually looks pretty good. Hope you don't mind if I copy your idea. I need to mount a fan on a PC case the same way (it's a very old case with no exhaust or intake fans anywhere other than the PSU fan).
here you can see the guetto mounted fan using a molex conector cutted from a cd drive and blue leds
more details later
Now that is 100% proper ghetto!
Cool PC, by the way. If I am not mistaken that PSU is a YoungYear / Apevia / Aspire unit. Those green sleeved cables should be UV-reactive - i.e. if you add ultra-violet lighting in the case, it will make those cables and their connectors glow too.
Good overclock on that C2D CPU too!
Quote:
Usually yes. But if you apply it carefully without pulling any strings from it, you can actually make it look pretty well. I do it around the cables of the probes of my cheap HF multimeters to prevent the cables from twisting and breaking. It looks almost like I have transparent sleeves on them. Eventually the glue does crack as I use them. But then all I have to do is re-heat the glue again and everything looks normal again.
Old 12-11-2018, 09:32 AM   #465
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
no, i hate re-melt wax.
for me, a pack of epoxy and a tube of UHU/Bostik clear adhesive is the almost universal fix.
stj is offline   Reply With Quote
Old 12-11-2018, 10:57 AM   #466
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Recently after trying hot melt glue (they're thermoplastic, not paraffin) I have a decision to use between hot melt vs epoxy... I like being able to reuse/repair hot melt where epoxy is pretty much set in stone after it sets.
Basically if it has to deal with any sort of heat, epoxy is used. If not, then hot melt glue.
On the other hand, is epoxy or hot melt glue cheaper per volume if I need to use it as potting material?
Old 12-11-2018, 01:51 PM   #467
Drack
Yup it's me
Drack's Avatar
Thanks, yes it's a nice way to mount a fan on a drive bay.
Actually I don't think that PSU is made by apevia, is not that good but not near as bad as most apevia I have seen
This is the PSU, actually you posted a couple times on that thread
https://www.badcaps.net/forum/showthread.php?t=58330
From what I saw is a topower or at least based on the design
Look
https://www.badcaps.net/forum/showpo...postcount=1931
He said something about leadman but I don't think they can make something decent lol
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
