hi i have question, can we remove Output capacitor (decoupling) in SMPS circuits, so we can get pulses while charging?
SMPS for charger Car battery
Re: SMPS for charger Car battery
You might be able to that but I would leave in C139 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
It will mess up the feedback signal feeding IC1 PIN 15. the steady DC output is also fed to the short circuit protection in Q6 section, and also feeds other circuits as well.
Why would you want to pulse charge in 50K ~ 100KHz?Never stop learning
Originally posted by budm View PostIt will mess up the feedback signal feeding IC1 PIN 15. the steady DC output is also fed to the short circuit protection in Q6 section, and also feeds other circuits as well.
Originally posted by frogz81 View PostCan we add Inductor and Decoupling Cap at Feed back path?(filter only at feedback path)
I also do not know if pulse charging at 50 ~ 100KHz will have any effect on de-sulfating or not. Do you know? Need to do more research.
You can try building some thing like this:
https://www.electronics-lab.com/proj...cid-batteries/
https://www.homemade-circuits.com/ba...uit-explained/
You can build this add on circuit which may be the best way to go without messing with the charger
Learning:
https://researchrepository.wvu.edu/c...26&context=etd
Notes:I did not look at the schematic to see if they are correct or not but at least it gives you the idea on how to pulse charge the batteries.Last edited by budm; 10-24-2020, 03:14 PM.Never stop learning
Originally posted by budm View PostLook at the circuit, you can see the DC output V+ and V- are fed to other circuits as well, not juts the feedback circuit only.
Learning:
Please do the follow-up on this project, thanks.Never stop learning
