Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting & Designing Networks
Old 05-10-2010, 11:56 AM   #1
mattch
City & State: Orlando FL
Line Voltage: 116V
Default cables
One time i was in a pinch, summer out, too hot for attic adventures and i needed to run another cable to my closet
there was already one cable ran and i couldnt use a switch because of how i have design the layout
so i re-wired the existing cable into 2 cables, this works becasue CAT5 cables only use 4pairs of the wire, there are 4 remaining pairs left, i seperated the 4 extra wires out the end and added plugs to both ends. works great and i still get full 100mbps throughput local.
mattch is offline   Reply With Quote
Old 05-10-2010, 12:34 PM   #2
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
Default Re: cables
its amusing how you can violate the recommended
- stick cables with hot glue
- run them next to power cables
- bend them pull them
i only had probs once by securing a cable with nailed in cable clips
most probs are by incorrect pinout at connector or bad crimping of connector. i always test the cables with cheap network tester though
funny how there is a magnetic like attraction of the cables to the feet of the ladder when you are pulling cables.
willawake is offline   Reply With Quote
Old 05-10-2010, 01:21 PM   #3
mattch
Line Voltage: 116V
Default Re: cables
totally agree, or around your foot while stretching on the ladder.
Cat5 cables seem to be able to take a lot, over flouro ligh fixtures, fridgerators, AC unit... i suppose it all depends on the requirments though..
i have had problems with pulling but that was becasue of my patients levels, a big knot and a truss
Cat6/a and fiber on the other hand.. like a woman.
Badcaps.net Technical Forums © 2003 - 2021
