Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 01-02-2021, 01:27 PM   #1
SuperAman
City & State: Addis Ababa
My Country: Ethiopia
I'm a: Knowledge Seeker
Default Toshiba laptop charger power supply problems
I have a laptop charger that is not working. I have tested it and the capacitor is storing high voltages around 600v. Both transistors are reading ok as well as all the diodes including the bridge diode. I replaced the C139 cap on output mosfet (it was cracked). All the resistors test ok in circuit. Am I missing something? D32 has a partial short reading in circuit but with one pad removed it has correct diode readings. The model of the board is adp-45fe bb.
SuperAman is offline   Reply With Quote
Old 01-02-2021, 01:33 PM   #2
SuperAman
Default Re: Toshiba laptop charger power supply problems
Old 01-02-2021, 02:18 PM   #3
Askic
City & State: Korce
My Country: Albania
So, are you saying that this big capacitor 82 uF, 420V has 600V??? This doesn't sound right.
Askic is offline   Reply With Quote
Old 01-02-2021, 07:02 PM   #4
SuperAman
Quote:
I am saying it is storing voltage, it is not going to the secondary or output side. I am measuring in AC so that might be why the number is high. Whatever the case, the cap stores voltage and when I use a lightbulb (serial bulb circuit) to test, it shows no short. However, if I don't discharge the cap with my meter and I touch the board cap area, I am shocked very badly.
Old 01-02-2021, 07:09 PM   #5
petehall347
City & State: worcester
My Country: United Kingdom
Quote:
are you for real ?
petehall347 is offline   Reply With Quote
Old 01-02-2021, 08:35 PM   #6
madan1
City & State: Sofia
My Country: Bulgaria
Remove all the white gunk from the board and post some nice clean photos.
Also, the most left cap ( c102? ) on the secondary side looks like a goner to me. Oh, and keep in mind that shocking yourself with a capacitor is not always the best way to check if it is ok or not.
madan1 is offline   Reply With Quote
Old 01-02-2021, 11:56 PM   #7
SuperAman
Ok will do. I accidently shocked myself, since it didn't show a short on the light bulb test, assumed it was ok. I am discharging the cap with my multimeter now after each time the charger has been plugged in.
Old 01-03-2021, 07:48 PM   #8
petehall347
what multi-meter do you have ? i want one that does that
Old 01-03-2021, 08:23 PM   #9
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I am thinking that this person is just seeing the capacitor slowly discharging
Because I also seem this myself
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 01-03-2021, 08:28 PM   #10
noizemaker
City & State: NA
My Country: Brazil
Speaking of notebook chargers, is it safe to remove Y cap from my Notebook charger (Lenovo Ideapad)? there is only one. I think it's connected to neutral-ground to filter EMI
However I'm using a surge suppressor with 2 Y caps
The Y cap in question on the charger is ce472m STE Y2 4700pF (quite high right?)
noizemaker is offline   Reply With Quote
Old 01-03-2021, 08:33 PM   #11
noizemaker
City & State: NA
My Country: Brazil
what could other benefit of a Y cap like 4700pF have on a Notebook charger?
Old 01-04-2021, 02:27 PM   #12
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Quote:
Some multimeters have a low impedance mode, with a 3K series resistor instead of 10M.
Those can be quite useful to discharge capacitors unless the capacitor is really large.
(If it is then the PTC's inside the meter will heat up and the resistance increases so they discharge much slower).
Some more details here: https://www.badcaps.net/forum/showth...076#post886076
__________________
Per Hansson is offline   Reply With Quote
Old 01-04-2021, 10:13 PM   #13
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
they all do that - once!
well maybe the 20A ones could do it a few times atleast - the cap can only hold a couple of amps if your lucky.
stj is offline   Reply With Quote
Old 01-05-2021, 04:10 AM   #14
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Electrolytic caps can only store a DC charge. Therefore, you should measure the DC voltage on that cap.
Not that I think this would reveal anything about the issue at this point.
I have a 15 KOhm, 5-Watt resistor for that purpose. When working on adapters like that, I always put this resistor across the main cap(s) - it discharges them in seconds. If the expected voltage is less than 320-340V, sometimes, I use my 4.7 KOhm 5-Watt resistor - really just a matter of whichever one I find first, most of the time.
+1
I doubt it. It appears to be United Chemicon brand. Unlikely to be bad, even in hot adapters like these.
Since the mains cap stays charged, I'm leaning more towards shorted output wires. Some PWM chips have crowbar protection and will latch down / stop all switching on primary until adapter is unplugged. So that's how the primary cap can stay charged for a long time.
Quote:
It's not unsafe.
But it's not recommended, though, for EMI/RFI suppression purposes, as you noted.
Also, it isn't necessarily connected Neutral to ground. If the Y-cap is near the switching transformer and connected between ground on the secondary and some part on the primary, that part is probably the negative (-) lead of the bulk cap.
are you for real ?
Why not?
I've done it a few times too (a couple on purpose too.) It's not dangerous as long as the discharge path is only through parts on one hand. Now if you discharge such cap across your body, that would be a lot more painful and dangerous.
Quote:
I think you meant to say Joules of energy instead of Amps?
Last edited by Per Hansson; 01-05-2021 at 06:38 AM.. Reason: Editing out double post
Old 01-05-2021, 06:32 AM   #15
stj
stj's Avatar
no, the ripple current of the cop relates to it's discharge rate.
Old 01-05-2021, 12:59 PM   #16
madan1
City & State: Sofia
About the cap - on the photo it looks like starting to bulge, but could be just the light.
I have two acer PSUs ( one for laptop, the other for a portable pc ).. both work fine, both are visually the same, have the same output V, but probably the PC one was a little bit more powerful ( if I remember correctly ).. anyway - the laptop one has a discharge resistor for the main cap, the other one - does not and keeps charge for hours even days after disconnected from the mains.
Old 01-05-2021, 09:46 PM   #17
stj
stj's Avatar
sounds simple, but check the output cable isnt broken or shorted internally.
Old 01-07-2021, 07:47 AM   #18
noizemaker
City & State: NA
My Country: Brazil
It's not unsafe.
why such high value for a Y cap in a notebook charger? besides shouldn't them come in pair?
4700pf would cause more noise in the neutral or ground than no Y cap at all. Let's assume this cap is connected between line and ground... this is ultra unsafe
Old 01-09-2021, 09:18 PM   #19
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
If you do see a pair of Y2-class caps, they are connected Live-to-Ground and Neutral-to-Ground... or like so:
[Live]--------||-------[Ground]-------||--------[Neutral]
But in cheaper/smaller power adapters, it's also not uncommon to not have the two Y2 class caps mentioned above and instead have only one Y2 cap between negative (-) primary bus (the negative of the primary cap) and ground / secondary-side ground/return.
Beyond my knowledge to explain exactly, but bigger cap shunts more of the high-frequency noise to ground, so Live and Neutral stay "cleaner", which means other devices connected to the same Live and Neutral will also see less EMI/RFI noise.
It's not if the cap is certified Y2 (or Y4) by safety agencies - meaning, it should go open-circuit in case it fails for whatever reason.
Old 01-21-2021, 10:26 PM   #20
SuperAman
I've tested nearly everything on this and it is either a bad ic31 chip or the small smd resistors feeding into it. Or a bad ic131 on the output side, I don't have these ic or resistors in my junk collection so have abandoned the repair.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
