Got this MoBo from guy to repair. First I checked memory, one module seemed bad so I swapped 2 of fours for a kit. Now there are 3 gigs in 4 Kingston memories.
However, it still does not run. When I tried Ubuntu, it seemed to be working on backroung, it e.g. reacted on Ctrl+Alt+Delete, the problem is there was no image.
With Windows installation (XP with3 different disks and versions) always hangs on:
Tried both SATA and UATA drives, upgraded to latest BIOS. Still nothing. Tried even just one memory stick. Do you think caps (Teapos) can make some device be bad so it does this, or is it more likely caps unrelated?
The signature for Windows XP Professional Setup is invalid. The error code is ffffc0d.
Setup failed to install product catalogs. This is a fatal error. The setup log files should contain more information.
