Unexpected quality, with a sting
    Thought I'd show the build quality of this MSI KM2M Combo before selling it
    Rubycon MBZ in the VRM, with heatsink on MOSFETs
    Chemicon KZE elsewhere, just three Teapo in lesser roles
    I got this a while ago, used, although everything looks original including soldering for all caps
    Drawback of the board is being extremely finicky about DDR
    I found if any double-sided DDR was used, whether as a pair or in conjunction with a single-sided one, there would be errors from Memtest which didn't necessarily show up in the first pass
    Wasted a lot of time testing memory, and other debugging - first XP build would consistently get windows\system32\config\system missing or corrupt on a cold start, even though it'd had one successful pass of Memtest, and disk etc. tested fine beforehand
    Was about to try SDRAM instead (it's a dual memory board) when I stumbled across its dislike of double-sided DDR
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    Re: Unexpected quality, with a sting
    Thanks for the timely report. I just picked up one of these boards in a package deal with a malfunctioning Asus core 2 board.
    I will definitely stick with single-sided DDR based on your experience.
      I recently found an MSI MS-7309 that's all Panasonic FJ except for some 100uF G-Luxuons and one 470uF, 16V Teapo.
      What RAM have you tried? Years ago, 60% of my Kingston 512MB PC3200 modules had errors, and last year I found 33% of Corsair 1GB modules were bad. All no-name chips, of course. With name brand chips I've had only one bad module, a CompUSA/PNY, and that was due to bad soldering:
        Double-sided 512MB DDR400 PQI in conjunction with a single-sided 256MB DDR400 PQI
        Double-sided 512MB DDR400 Veritech in conjunction with a single-sided 256MB DDR400 Veritech
        Pair of double-sided 512MB DDR400 Kingston with Hynix chips
        Pair of double-sided 512MB DDR400 Kingmax
        Pair of double-sided 256MB DDR266 generic with Hynix chips
        All of the above have been extensively tested in other boards, without an issue
        No problems with a single-sided 512MB DDR400 Kingston in conjunction with a single-sided 512MB DDR400 Elixir, and a pair of single-sided 512MB DDR400 Starmax
          All of the PNY RAM I have seen used no-name chips. Some used PNY branded chips (made by an unknown company), and one had chips marked "BRAVO."
            I would try a VDIMM increase. I wouldn't be surprised if it's undervolting.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            16 GB AData XPG Spectrix D41
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
