MS-7548 (Aspen) wont turn off
    so i have this board in my build... it started giving me a fan failure notice and the board would turn off....
    i switched the fans 3 times still gave me an error...so i looked at the caps and 1 was bulged.i replaced it (100UF, 6.3V)and i benched tested the board and it worked slowly...found a better cap( Rubycon ) and it worked faster...
    then i shut off the system...
    came back to it an hour later and the system turned on by itself...
    *** bench tested with a Antec 350w ps 1 g ddr2 an vid card connected to a surge protector***
    Now the board stays on a soon as i plug the ps on .... tried 2 ps sill same results...it wont post unless i also flip the PSW switch...then it works ok...
    any suggestions..
