This Samsung un40eh5000f has blue line from bottom to top just one very thin.i pressed on tabs and cleaned strips to no avail.I think its a defect in panel at moment.Haven't ruled out t-con as i don't have replacement.For testing can you switch around cables on t-con to energize other side of panel to rule out that side?
samsung un40eh5000f with thin vertical line
Re: samsung un40eh5000f with thin vertical line
Thanks Andrew:I just switched cables around on t-con and confirmed that indeed the panel is defective.Yes t-con issues usually appear different than a single blue line.Too bad though ,well got some spare parts anyway keep some waste out of landfill.
