I was recapping some Chaintech Apogee board but probably due to some bad soldering near memory regulators something burned as soon as I turned it on. I identified it was probably coming from an rt9173 chip which is voltage regulator. I measured the VOUT pin and it reads 0,7 V only - too low for memory. The boards beeps as it detects no memory - so I guess it really is this chip?
Board do not start - burned voltage regulator?
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Tags: None
Re: Board do not start - burned voltage regulator?
I of course measured them, but they did not seem shorted. Also the board was more heated around the regulator than mosfets.Less jewellery, more gold into electrotech industry! Half of the computer problems is caused by bad contacts
Why do you think RT9173 is for RAM power?
Did you trace the circuit?
There are other RAM related voltages that are less than the power voltage.
I'm just saying check to see what it powers.............Mann-Made Global Warming.
- Dr Seuss
MOSFETs regulate by switching.
The switching is controlled by an IC chip [or chips.].
Those IC chips have regulators to control their voltages that are not MOSFETs.
THOSE regulators can be just a transistor or yet another IC chip.
One popular type [on mobos] is called an LDO regualtor. {Low Drop Out}
If the power regulator to the IC chip that controls the MOSFET is screwed up then so can be the output of the MOSFET.
LDOs are also used to power IC chips that have nothing to do with MOSFETs.
There is usually at least one regulating any IC chip and there's usually a cluster of them around the chipset.
Does your head hurt yet?
http://www.google.com/#sclient=psy&h...bb86640ae08969
.Last edited by PCBONEZ; 04-15-2011, 02:58 PM.Mann-Made Global Warming.
- Dr Seuss
I did not trace it precisely, but it's closest to RAM and also as I said, the RAM's are getting much lower votlage than they should (I meassured actually) so they are not able to start and board thinks there are no modules at all.Less jewellery, more gold into electrotech industry! Half of the computer problems is caused by bad contacts
Changed the regulator, ther was indeed also one MOSFET burned. Changed it for some from the dead ASUS board I asked about in next thread - it had the same or superior values and same RdsON (14 mΩ). Now the boards runs, just memory shows indefinite amount of errors in Memtest86+. Will try to solder it better and also newrer version of the program.Less jewellery, more gold into electrotech industry! Half of the computer problems is caused by bad contacts
The original MOSFET was IRL3175S, I used one 9918H.
It looks loke the regulator heats up more than what I consider to be cool, but I can still keep my finger on so it's not so bad.Less jewellery, more gold into electrotech industry! Half of the computer problems is caused by bad contacts
Resoldered all legs once again. Also tried to measure voltage on small ceramics on memory module, it shows some 2,64 V which is fine for DDR. Memtest86+ v4.10 now running, so lets hope
ADD// no error so far, first pass almost done.Last edited by Behemot; 05-31-2011, 01:38 PM.Less jewellery, more gold into electrotech industry! Half of the computer problems is caused by bad contacts
