Hi I have two smd resistors of different value one R100 and the other R220 that I want to replace what alternative value can I have ? they are from two different HD motherboard that I am trying to repai
Smd resistor alternativ
Re: Smd resistor alternativ
https://www.badcaps.net/forum/showth...light=bohaboha .it's to a hard drive that both don't work if you want a picture of them? but in general which is the closest replacement that you can use because I don't have at home
Wait, does the resistor say Rxxx on it, or does the board say Rxxx on it? If the labels are on the resistors then they indicate size like jiroy mentioned, but if they're on the board then they're just an internal reference number for the board designer and factory to use and don't tell us much without a boardview or schematic.
The best way to get a value is to remove the parts and measure them as small SMD resistors are often not labeled. Then a measurement of length and width (usu. in thousandths of an inch, easiest to measure mm and convert, or use calipers) will tell you what package you need to order.
Edit: dad gum typos...Last edited by JNP-3R; 02-14-2023, 12:15 AM.All we have is each other. PLUR y'all!
