Go Back   Badcaps Forums > Motherboards with Bad Capacitors > ECS - EpoX - Gigabyte
Old 03-15-2017, 01:24 AM   #1
pfrcom
Oldbie
City & State: Melbourne, Victoria
My Country: Australia
Line Voltage: 240v
I'm a: Hobbyist Tech
Default GA-8IG1000MK with bloated Rubycon MBZ (pic heavy)
Acquired this recently, and found hard to believe ...
... five bloated Rubycon MBZ around PCI and AGP slots
Perhaps not too surprising when one sees heat discolouration underneath the FETs between AGP & PCI1
Matched by discolouration beneath VRM
Latter weird, considering VRM has Rubycon input and Sanyo output
Was advised board had been liquid cooled, and stopped working reliably if multiple DIMMs were used, after a leak
So I also removed caps between memory slots, to find
Bloated MBZ replaced by Sanyo WG - also replaced two non-bloated MBZ
DIMM area, after clean-up
Board overall, after cleaning off coolant stains with wet microfibre cloth
Could be worse though
Unfortunately multiple DIMMs are still not reliable - board's BIOS swaps between OK & Fail for 2.5V health status
However two DIMMs were OK for four passes of Memtest86+
And did a clean XP install without an issue
Then Prime95 didn't even get through a single pass
And stress test of Aida64 also didn't go too far
Aida64's sensor display showed some weird numbers for 2.5V - swapping from ~0.8V to ~1.7V
However Aida64 also showed 5V as 4.1 - but DMM measured 5.03 on spare Molex connector
PSU is a recapped Antec SL300S
Caps between AGP & PCI1 heat up to temperature most unpleasant to put finger on
Where to go from here ?
pfrcom is offline   Reply With Quote
Old 03-15-2017, 07:21 AM   #2
Wester547
City & State: CA.
My Country: USA.
Line Voltage: 120-125VAC 60Hz.
Default Re: GA-8IG1000MK with bloated Rubycon MBZ (pic heavy)
The attachments don't work. The link in red shows bad 2004-2005? Nichicon HM and KZG. No surprise there. The software sensors are never reliable, best not to place any trust in them (but the low +5V reading could be a pin or two on the ATX 20-pin connector, if it really is low). Is there any discoloration underneath the DIMM area? Any chance of trace corrosion (as the resulting effects of the leak from the liquid coolant) or oxidization that may be causing only one DIMM to work, even after cleaning the board? The two linear regulators by the AGP slot, I would imagine, do run precariously hot. No surprise there either.
Wester547 is offline   Reply With Quote
Old 03-15-2017, 08:04 PM   #3
pfrcom
Oldbie
Line Voltage: 240v
They're hosted on Badcaps, not sure what could be the problem
Can anyone else confirm it's an issue for them please
Old 03-15-2017, 10:29 PM   #4
Dan81
SNES-powered
Dan81's Avatar
City & State: Romania
My Country: Bacau
Line Voltage: 230VAC 50Hz
He's right,I can't see them either.
Main rig:
DFI Lanparty DK P45-T2RS, Intel Xeon X5450 3.00GHz, Sapphire Radeon R7 240 2GB DDR3, 8GB DDR2-800, LiteOn DVD-RW drive, RPC 500LBL 500W (rebuilt), AVerMedia Super 009 TV tuner, Samsung HD103SI 1TB, noname black case
Dan81 is offline   Reply With Quote
Old 03-16-2017, 06:46 PM   #5
pfrcom
Oldbie
Line Voltage: 240v
Old 03-17-2017, 01:22 AM   #6
pfrcom
Oldbie
Line Voltage: 240v
I should have known better ...
... the penny finally dropped that I was using a 3.0 Northwood with a missing pin
So I swapped in a 3.0 Northwood with all pins intact, and you've guessed it ...
... self-tests 1024K and 8K of Prime95 passed, and continuing
Old 03-17-2017, 01:28 AM   #7
pfrcom
Oldbie
Line Voltage: 240v
Clicking on the IMG tags in question brings up a page that says the attachments are invalid. Uploading the attachments without the aforementioned IMG tags should work.
I phrased too briefly - originally I followed FAQ and clicked mountains? icon for each inline image, then pasted each upload's URL - which yields IMG tags
FWIW, I cleared Waterfox cache, then I couldn't see images either
Old 03-17-2017, 08:25 AM   #8
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 120VAC 60Hz
I fixed the images.
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 03-17-2017, 07:03 PM   #9
pfrcom
Oldbie
Line Voltage: 240v
Originally Posted by Topcat View Post
I fixed the images.
Thank you, thread now much cleaner
Old 03-20-2017, 02:36 AM   #10
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
well i guess thats the issue with water cooling. due to that, the fallacy is to neglect cooling or ventilating the board properly. so what i think happened was that there was no airflow over the board due to water cooling being used. so the mosfets all overheated and discoloured the pcb. the bloated caps over a large area of the board is a telltale sign of a poorly ventilated pc case.
for normal air cooling, the cpu fan will give a slight breeze over the board. i've seen a number of cases in overclocking forums whereby when someone upgraded to water cooling, the overclocking got worse or more unstable. the culprit was found to be lack of airflow over the board and overheating mosfets during overclocking. after some mosfet heatsinks were added and a side panel fan installed blowing air over the board, it was business as usual overclocking.
ChaosLegionnaire is offline   Reply With Quote
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
