Old 02-20-2018, 05:24 PM   #1
Lakerfever
City & State: Hesperia California
Default Vizio e420i-b0
Hello Im having trouble with this TV wont stay on turns on for about 2 seconds shows vizio logo then turns off the standby white light fades away shortly after I have replaced the main board 2x (used) with the issue still remaining i even changed the supply board still have the exact same issue i have cleaned around the power button making sure it wasnt stuck is there another component i need to check or test? any help would be appreciated attached are the main and supply boards..
Lakerfever is offline   Reply With Quote
Old 02-21-2018, 09:28 AM   #2
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
Default Re: Vizio e420i-b0
Sounds to me you have bad LED backlight issue. Not Main Bd or PSU.
Andrew F. Ali is offline   Reply With Quote
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
