Old 02-10-2018, 09:53 AM   #21
Davi.p
City & State: Milan
My Country: Italy
Line Voltage: 230Vac 50Hz
I'm a: Hobbyist Tech
Default Re: Can a small crack kill the whole panel?
If you input an AV signal have you at least sound?
Davi.p is offline   Reply With Quote
Old 02-12-2018, 11:43 AM   #22
Gorrillasnot
City & State: USA
Sorry it took a while to respond. The past few days have been hectic.
Yes I have sound. I hooked my laptop up to it via hdmi and played a video clip and the sound played through the TV.
Does that mean the problem is likely the panel is completely dead? or possibly the t-con? When I first put the tv back together the ribbon cables going to the t-con were off a little..maybe this shorted something out?
although the fuse is not blown so that is probably unlikely?
thanks
Gorrillasnot is offline   Reply With Quote
Old 02-13-2018, 04:05 AM   #23
mmartell
City & State: Windsor ON
My Country: Canada
I noticed the tcon cables being offset as well. In fact I thought I killed my panel when I first fired it up.
How much is a replacement tcon ?
mmartell is offline   Reply With Quote
Old 02-13-2018, 05:25 AM   #24
Davi.p
City & State: Milan
My Country: Italy
me too..
It's possible!
Note: my keyboard is not working, used onscreen one..
I see in the tcon photo there are on the right 3 testpoints, Avdd, Vgl, Vgh, test them in volt and report here, the others 2 tensions must be around 1v and 3,3v, you have to search them testing all the coils both ends.
Old 02-14-2018, 12:27 PM   #25
Gorrillasnot
City & State: USA
Originally Posted by davi.p View Post
i see in the tcon photo there are on the right 3 testpoints, avdd, vgl, vgh, test them in volt and report here, the others 2 tensions must be around 1v and 3,3v, you have to search them testing all the coils both ends.
Those t-con test points measured AVDD 1v, VGH .9v, and VGL .1v
A replacement t-con is fairly cheap for this TV at around $5 shipped without ribbon cables and $9 with.
Does it seem like the t-con is the problem?
thanks
Old 02-14-2018, 01:36 PM   #26
Davi.p
City & State: Milan
My Country: Italy
tcon is faulty.
Old 02-14-2018, 02:05 PM   #27
Gorrillasnot
City & State: USA
tcon is faulty.
thanks for the info..I will order 1 and see how it goes.
thanks
Old 02-14-2018, 03:24 PM   #28
Davi.p
City & State: Milan
My Country: Italy
5$?? It's a gift..
Old 02-20-2018, 01:27 PM   #29
Gorrillasnot
City & State: USA
I received my t-con today. I installed it and the TV now works.
I was hoping that small crack would only affect the corner where it was, but nope it causes vertical lines top to bottom on the left side of the screen.
I temporarily put some painters tape over the lines and it helped a little.
So while far from ideal it works. I think I'll hang it out in the garage and watch youtube vids while I wrench.
thanks everyone
Old 02-20-2018, 02:00 PM   #30
freakaftr8
freakaftr8's Avatar
City & State: Folsom, CA
Line Voltage: 120vac 60hz
Nice! At least it looks good!
freakaftr8 is offline   Reply With Quote
Old 02-20-2018, 02:02 PM   #31
freakaftr8
freakaftr8's Avatar
In the past to keep air from getting into the panel in spreading the crack I have used super glue along the perimeters of for the crack where it starts and ends including the crack along the screen if it's surfaced.
Old 02-21-2018, 05:08 AM   #32
mmartell
My Country: Canada
Hey good save ! Looks alot better than it did when it didn't work at all
Old 02-21-2018, 12:47 PM   #33
Gorrillasnot
City & State: USA
Good tip. I think I'll try that.
thanks
For sure lol
thanks again everyone
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
