Old 03-29-2017, 06:31 PM   #1
caibbor
City & State: Paw Paw, MI
Default Toshiba 50L1350U - Dual Image/Horizontal Shift After Power Outage
Toshiba 47" (I think) TV
Model 50L1350U
Chassis Unkown (pictures included)
This happened right after a day of power outages, so I presume there was a surge. It worked fine for the duration of most of a movie after the outages, and then started doing this. Everything seems to work just fine except for the "shiftiness" which you can see in the pictures. This happens to the OSD stuff as well as the movies. Happens with HDMI as well as analog RCA input. Nothing else seems to be amiss.
I already opened the back to check for any fuses or burnt looking components. I have a multi-meter and a soldering iron. Not afraid to get my hands dirty on this one (I am a PC repair tech, never worked with TVs before). There is a fuse in the back, but I'm not sure how to tell if it's bad.
If it were a computer, I'd point at the video chip and replace it (or the board it's attached to). So I'm tempted to just replace the motherboard as well as what looks like the power supply board and see what happens, but I wanted some of your experienced advice before I spent any money.
Lots of pictures included. Some are huge, so instead of blowing up the size of this page I made links to most of them.
http://i.imgur.com/nT9JLti.jpg
http://i.imgur.com/K4Ld3mp.jpg
http://i.imgur.com/hZBejiQ.jpg
http://i.imgur.com/VvIBEBS.jpg
http://i.imgur.com/LKNWWfL.jpg
more close-up imaged can be found here: http://caibbor.imgur.com/all/
Thanks you in advance!
caibbor is offline   Reply With Quote
Old 03-29-2017, 06:42 PM   #2
heavymachines
City & State: Muskegon, Michigan
My Country: United States
Line Voltage: 120VAC 60Hz
Default Re: Toshiba 50L1350U - Dual Image/Horizontal Shift After Power Outage
Nevermind
heavymachines is offline   Reply With Quote
Old 03-30-2017, 03:26 PM   #3
freakaftr8
freakaftr8's Avatar
City & State: Folsom, CA
Line Voltage: 120vac 60hz
I'm a: Hobbyist Tech
Is the picture flickering well you're getting the dual image? This sure does look like panel failure
freakaftr8 is offline   Reply With Quote
Old 04-13-2017, 11:14 AM   #4
caibbor
The "dual image" kind goes from a normal image back to dual every second or so (sometimes less, sometimes more).
It's like it wants to go "into focus" but just can't.
the light doesn't flicker, no. the backlight stays on entirely.
Old 04-13-2017, 04:54 PM   #5
freakaftr8
freakaftr8's Avatar
That's panel failure. Try this take off the metal frame exposing the LCD panel edges and use a heat gun and heat up the edges from top to bottom each side as you're watching the picture period does it straighten out?
Old 04-14-2017, 12:36 PM   #6
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
Can't help on this but perhaps you can help someone else who has a similar set with a different problem.
What reading do you have for the voltage driving the leds?
dick_barton is offline   Reply With Quote
Old 07-27-2017, 07:00 PM   #7
caibbor
I took a heatgun to the edges and sides and everything, I didn't notice any difference. I didn't get it TOO hot, but it was a legit heat gun and warmed it up pretty good. What else do you suggest I do?
Sorry this took so long, but I'd be happy to help. You just want the voltage between the on/off LED? I'm not sure what a "driving led" is.
Old 07-28-2017, 05:35 AM   #8
dick_barton
My Country: Wales
Someone else was having problems and couldn't decide what the voltage to the panel leds for this set should be. The thought was anyone else with this model doing a search on the forum would have the answer.
Old 07-29-2017, 08:15 AM   #9
nomoresonys
City & State: midwest
My Country: U.S.
The storm may have cooked something, I'd try to find a reasonable main board as a start, good luck.
nomoresonys is offline   Reply With Quote
Old 07-29-2017, 10:45 PM   #10
caibbor
After I tried the heat gun trick, I gave up and walked away an left the TV on. I came back to find the TV was no longer displaying anything at all and no backlight. So as it stands, it just doesn't do anything at all.
considering replacing the mainboard.
Old 02-20-2018, 09:54 PM   #11
nomoresonys
My Country: U.S.
Any progress?
Old 02-21-2018, 02:28 AM   #12
koka0011
City & State: Gampaha
My Country: Sri Lanka
did you cut ckv lines?
koka0011 is offline   Reply With Quote
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
