Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 02-20-2018, 05:19 AM   #41
tn245
City & State: South East
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Knowledge Seeker
Default Re: Pioneer Kuro PDP-LX5090 buzzing and crackling
You need to take off the front plastic bezel, and then the top edge of the metal frame that overlaps the panel. The EMI strip is attached inside the frame wedged between it and the glass panel. Be gentle with the panel!
tn245 is offline   Reply With Quote
Old 02-20-2018, 09:36 PM   #42
Matcat
City & State: NORWOOD
My Country: Australia
im having trouble taking the front bezel off, the clips on the top are hard to release. thanks
Matcat is offline   Reply With Quote
Old 02-21-2018, 02:55 AM   #43
tn245
My Country: UK
Remove the four screws/plugs along the bottom edge of the bezel plus two long screws that go through the back of the TV into the bezel at either end of the TV (prob already removed if back is off). Then you have to hinge the whole bezel up from the bottom to about 30 degrees and it will come off the clips at the top. I'm assuming it's the same as the 9G models I've worked on. Otherwise if you can get the service manual it should have instructions.
Old 02-22-2018, 12:42 AM   #44
Matcat
how do the clips come out, do i just pull them straight out? i dont want to break anything.
Old 02-22-2018, 08:24 AM   #45
tn245
My Country: UK
The ones along the bottom? Unscrew the screws maybe half way and then pull the screw to pull the little plug out with it. The ones on the top should release easily once the bezel is lifted to the required angle.
Old 02-23-2018, 05:24 AM   #46
Matcat
when i pull off the metal frame on all sides there is no crackling sound and there is way less buzz. emi strip doesnt look degraded but does look flattened out a bit (never done this before)does that mean it needs new emi strip?is it the same strip you linked? thanks
Old 02-23-2018, 05:44 AM   #47
tn245
My Country: UK
Probably yes. Without the frame there is nothing to arc to. On mine the foam inside the strip was obviously deteriorated and the strip looked hollow is how I would describe it. But also you can take a multimeter on continuity/diode/ohms mode and measure between the surface of the strip and the metal frame at various points. You should get a beep or low ohms all the way along. If not it's not conducting well and should be replaced.
Old 02-23-2018, 06:40 AM   #48
Matcat
most of the strips are hollow, if i push down hard enough i get conductivity
Old 02-23-2018, 06:50 AM   #49
tn245
My Country: UK
Definitely replace them.
Old 03-26-2018, 01:48 PM   #50
Matcat
ok received the strips they are the same ones you linked.
how do i apply them? they are 30 cm long and they are not cut straight.
do i cut them straight? do i overlap them so there are no gaps?
thanks
Old 03-26-2018, 03:36 PM   #51
tn245
My Country: UK
You can cut the ends straight so they meet a bit more flush but I wouldn't overlap as it would end up too thick. Just try to get them to meet up nice and close without a gap. It's not too difficult.
Old 04-09-2018, 06:53 AM   #52
Matcat
ok replaced the strips and put back together the tv
the static sound has completely gone. Thank-you
It still buzzes fairly loudly, seems to be coming from the coils at the back of the unit, is there any solution for this?
Old 04-09-2018, 08:25 AM   #53
tn245
My Country: UK
Yup. As I mentioned earlier in the thread, it seems some just do buzz more than others. One I had later on had the EMI strips in perfect condition but was louder than the one I replaced them on. If you read through you'll see I did dunk the vsus transformer in varnish before I figured out the strips were bad which may have contributed a little to quietening that one. I guess some of us were hoping this would be a magic solution to making our Kuros super quiet but it looks like it may only help in some of the cases.
How does the buzz volume compare to when you had the frame off?
Glad it helped out with the static sound at least.
Old 04-09-2018, 08:28 AM   #54
tn245
My Country: UK
Also as previously mentioned, energy save mode 2 seems a necessity for some of them.
Old 04-09-2018, 08:41 AM   #55
Matcat
pretty sure the buzzing was way less with the frames off but i cant be sure
energy save mode 2 helps a bit
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
