Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 02-13-2018, 03:07 PM   #41
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: Powersupply washingmachine. Relay problem?
I bet the problem is the (ipm) actually it is a CIPOS. I am going to take a guess and suggest you check that part.
You should be able to diode test the output, check between P-U, P-V, V-W, W-NU, V-NV, W-NW. this should be the layout looking at the back of the board
The voltage on the KIA78R15PI is a bit low and might effect operation, it supplies the low side control of the cipos ic, depending on what the part number is it should be around 15-16 volts
R_J is offline   Reply With Quote
Old 02-13-2018, 03:22 PM   #42
Moreno83
City & State: Overijssel
My Country: The Netherlands
Line Voltage: 230V
I took the gamble and heated up the topside of the board with a heat gun with most heat going to the capacitors. The voltage on the regulator changed from 12 to 13.5v and its now running a program. Im waiting to see if it finishes the program.
The regulator has to be 15v , i measured on the good board.
So either because of heat the board expands and fixes a loose connection OR the heat charges for example the capacitors or spool?
What do you say?
Moreno83 is offline   Reply With Quote
Old 02-13-2018, 03:31 PM   #43
R_J
City & State: ☻
My Country: Canada
Check the input voltage to the regulator and see if it changes when heated, I believe the cipos ic requires a minimum of 14 volts, 12 would be too low for it to operate.
There are 3 diodes that supply voltage from the transformer the one you measured before supplies the regulator ic, the other 2 are D5 and the one beside it, check there voltage also.
The cap CE9 in the primary could be bad and it would effect all the output voltages, the other 2 I circled are the input and putput oc the 15 volt regulator ic. I marked with arrows the output voltage test points
Old 02-13-2018, 04:15 PM   #44
Moreno83
Line Voltage: 230V
Thanks for the pictures , helps people in the future.
It did not finish the program because the voltage went down to 13.2v. I heated up the board again and just in the area of the small caps. The diode voltage goes from 17.3 on cold start to 16.9/17 when heated so the input voltage goes down. It looks like its stabilising if that makes sense.
I got it eventually to 13.6v and it ran the motor again.
Funny thing is that the voltage is fluctuating when it goes below 13.5v because it tries to start the program and "pulls" down some component.
The upper right cap that is marked in the picture above is not standing straight on the board like all the others. Maybe the silicon pulled the capacitor out because of vibration?
I got the caps so i can swap them?
Old 02-13-2018, 04:41 PM   #45
R_J
City & State: ☻
My Country: Canada
That is just a basic smps. 17 volts should be enough to get 15 volts out of the regulator ic, but if the caps are weak that could be the problem. if changing those caps does'nt fix it I would replace that regulator ic next. 13.2 volts is too low, 13.5 is the minimum voltage for the ic motor drive ic to run. So it looks like that cipos is ok and the low voltage is the issue.
Old 02-13-2018, 10:28 PM   #46
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
I'm a: Knowledge Seeker
Great troubleshooting so far.
I have seen these KIA switched LDO regulator goes out a lot in the Sharp TV, it uses 12V version.
It has really low drop out Voltage so I do expect it to be able to put out 15V easily with 17V input.
__________________
budm is online now   Reply With Quote
Old 02-15-2018, 01:30 AM   #47
Moreno83
Line Voltage: 230V
I replaced all the caps and i still got 12v on the regulator. This makes me believe the regulator is bad because when i heat it up it will go up to 13.6v. ( or heat is spreading around the board...... )
I got this sharp powersupply somewhere. Do you mean this PS or a different one?
Old 02-15-2018, 01:46 AM   #48
budm
budm's Avatar
My Country: USA
That Sharp uses SWITCHED 12V IC for the 12V_PANEL, you need the 15V one for your circuit.
Old 02-15-2018, 11:18 AM   #49
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Quote:
and what is the voltage input to the regulator? Does it go up and down too, when you apply heat?
CapLeaker is offline   Reply With Quote
Old 02-15-2018, 01:03 PM   #50
Moreno83
Line Voltage: 230V
Quote:
It starts on 17.3v cold start and when i apply heat the output goes up and the input goes a tiny bit down to 17v.
Datasheet says it needs atleast 16v to make it 15v so im pretty sure its the regulator.
Old 02-15-2018, 01:33 PM   #51
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
Sounds like it... anyway it would be exactly that what I'd be doing.
Old 02-15-2018, 01:47 PM   #52
Moreno83
Line Voltage: 230V
Will let you guys know when the part is installed. Waiting for the post....
Old 02-19-2018, 11:08 AM   #53
Moreno83
Line Voltage: 230V
Replaced KIA78R15PI and the machine is now running like new! Thanks everybody and especially R J for all the help , i learned some new things and i can make someone happy!
Total cost , $3.
Old 02-19-2018, 05:39 PM   #54
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
Good job Morneno!
Old 02-19-2018, 06:44 PM   #55
budm
budm's Avatar
My Country: USA
Thanks for the follow-up.
Old 02-19-2018, 09:09 PM   #56
R_J
City & State: ☻
My Country: Canada
Glad to here you got it working.
Old Yesterday, 06:10 PM   #57
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I had a feeling that this KIA78R15PI chip was not working right
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
