I had it stored for a while, but IIRC, it just didn't react at all when I powered it up. I took it apart, and found four capacitors that have popped on the power supply board. The capacitors are green, made by Samxon, and are rated for 470 uF and 25V. I'm afraid I may have been too hasty in removing one of the capacitors - part of the PCB got lifted. I don't think the damage was extensive enough to solder in another wire.
A bunch of us were able to find four replacements, rated at 470 uF and 35V. I forgot the brand, but will note it. I have to take it apart again anyway. I believe the soldering was adequate and sufficient.
I turned it on, and yes, the power button shined blue, the LCD backlight activated and the floating RGB box appeared. An amber light appeared as the image and backlight went out (the monitor wasn't attached to video output).
I tried turning it on again, but all I got was a faint strobing backlight with no image (at least of the floating RGB box). The only other reaction I got was a blue box with the letters "ISP" appearing on the lower right of the LCD. The backlights were also activated in that instance. I can't replicate that condition, but I believe pressing the control panel buttons on side got the process going.
I'm reading the thread on the Gateway 900G with great interest, too.
I'd love to know what other things warrant further examination.
Thanks for reading!
Thanks for reading!
