Thanks ahead of time for your help and consideration.
I am trying to troubleshoot and fix a Vizio E470VL and I am unsure what to do next. I have read numerous threads related to my TV and issue (found one with the exact same issue that the user decided to give up and swap out the data board) with no solution.
I believe my problem began with a power surge that killed the TV (but I also recently noticed that onc of the HDMI ports started to not work before the tv failed) and I was left with a TV with no power light. I checked the fuses and I replaced F1 on the main board. The power light is now working, but I get no response from the power button or remote. I examined both boards and did not see anything out the the ordinary in terms of damage or bulging caps.
I currently have the following voltages:
The harness going from the power board to the main board:
DIM.............0.694v
LAMP............0v
I-ON/OFF......0v
PS_ON.........1.14v Steady, get a quick 3.096 at first measurement
12V..............12.19v
12V..............12.18v
SGND...........0v
SGND...........0v
SGND...........0v
SGND...........0v
5V................5.06v
5V................5.07v
U8 (7805LT)........12.14v, 0v, 4.96v
U2 (1117)...........2.02v, 3.264v, 4.92v
U7 (1117)...........2.007v, 3.236v, 4.82v
U4 (1117)...........0v, .323v, .527v (Others stated this s/b 0, 1.25, 3.3)
U3 (G1084).........0.315v, .518v, 4.83v (Feeds U4, low adjusting V)
U46 (1117).........1.986v, 3.22v, 4.84v
U33 (4953GM)
0 -------11.93 (Gates are not switching)
0--------12.16
0--------11.93
0--------12.16
What additional information can I provide?
LAMP............0v
I-ON/OFF......0v
SGND...........0v
SGND...........0v
SGND...........0v
SGND...........0v
U33 (4953GM)
0--------12.16
0--------11.93
0--------12.16
