I need help on this please hp mini 210-1018cl board idANM6AMB6F0 REV F: it came dead the problem is the 19v rail at first check pq32 pin has 19v but pin 2 0v and pin3 has 0.9v, so i replaced pq32 it works now there is a light and laptop can turn on and boots fine after a minute it goes dead again check again pq32 same as before no voltage on pin 2 and pin 3 has 0.9v so and check the fuse R030 markings has 0.9v so i replaced the fuse now 19v present and laptop can turn on and boots fine, but still same issue after a minute it goes dead again and no voltages on pq32 and the fuse R030.could anyone help on this please. if a put votages using bench lab on pq32 and R030 FUSE ligts present then goes off and taking 0.01miliamps on bench lab
hp mini 210-1018cl 19v rail problem
Re: hp mini 210-1018cl 19v rail problem
change
PU2
ISL6251A
or
pu2 ic islxxxxx numberLast edited by Stevie2001; 06-20-2018, 11:23 AM.
Originally posted by Romulo View PostI need help on this please hp mini 210-1018cl board idANM6AMB6F0 REV F: it came dead the problem is the 19v rail at first check pq32 pin has 19v but pin 2 0v and pin3 has 0.9v, so i replaced pq32 it works now there is a light and laptop can turn on and boots fine after a minute it goes dead again check again pq32 same as before no voltage on pin 2 and pin 3 has 0.9v so and check the fuse R030 markings has 0.9v so i replaced the fuse now 19v present and laptop can turn on and boots fine, but still same issue after a minute it goes dead again and no voltages on pq32 and the fuse R030.could anyone help on this please. if a put votages using bench lab on pq32 and R030 FUSE ligts present then goes off and taking 0.01miliamps on bench lab
Originally posted by Stevie2001 View PostDownload board view for your borad or buy one.
Youtube mb boardview learn reflow on short makes no sense
