Hi All! This my first posting. I have a dead Sharp AQUOS tv model LC-60LE633U. I get 2 long flashes followed by 5 short rapid flashes on the front power light. I checked power supply voltages for those I could access and saw the 12 volt dc supply measured 7.35 volts instead of 12vdc. I isolated the 12vdc supply pin from where it went to Main Logic board. The voltage was still 7.35vdc so I don't think Main board is draining missing voltage. I traced the 12vdc power from a Low Voltage Dropout Regulator (LVDR). I plan to replace the LVDR and go from there. The power supply initially supplies voltages but they all drop back to 0 after 5 short rapid flashes start. Has anyone seen this issue with this model Sharp tv? Thanks for any advice for further checking.
Re: Sharp AQUOS tv model LC-60LE633U
Originally posted by DAVEMAC02 View PostHi All! This my first posting. I have a dead Sharp AQUOS tv model LC-60LE633U. I get 2 long flashes followed by 5 short rapid flashes on the front power light. I checked power supply voltages for those I could access and saw the 12 volt dc supply measured 7.35 volts instead of 12vdc. I isolated the 12vdc supply pin from where it went to Main Logic board. The voltage was still 7.35vdc so I don't think Main board is draining missing voltage. I traced the 12vdc power from a Low Voltage Dropout Regulator (LVDR). I plan to replace the LVDR and go from there. The power supply initially supplies voltages but they all drop back to 0 after 5 short rapid flashes start. Has anyone seen this issue with this model Sharp tv? Thanks for any advice for further checking.Never stop learning
Budm, you are spot on. The device is a LDO with 4 leads. Lead 1 voltage in, lead 2 voltage out, lead 3 Gnd, and lead 4 Control. I have the 13 volt input but not the correct output. I also read 2.72vdc on control lead. Your LC/LED Primer on these tv power supplies is outstanding. Where would I read the 24vdc on the power supply connector going to the Main Logic board? When I replace the LDO, this may cure the problem...I'll let you know. Thanks for the guidance.
If the ldvr has been a problem as budm suggests, replace it first, If there is still an issue, I would disconect the wire cables first, if that allows the voltage to stay up, then reconnect them and disconnect the flat ribbons going to the panel.
Likely the lvdr will fix it. the control on pin requires min 2 volts and you have 2.7 so it should be onLast edited by R_J; 06-10-2018, 12:42 PM.
R_J, thanks for the suggestion. I will replace LDO and then check operation. Any idea on how much thermal grease/paste to use between heat sink and LDO device? I understand grease or paste is not so much for insulation but to eliminate air spaces that would decrease efficiency of heat dissipation...is this correct? Thanks
