Cannot help with very poor quality pictures. I cannot read anything on the main board except the P/N of the board..
Hi posted some better pictures could it be my power switch is broken since I'm receiving voltage on the power board also how many volts should I be getting on the other board? not the power board
If you know which conductors bring power TO the board, look at the voltage rating of the caps that it encounters, there. The supplied voltage will not exceed the WVDC ratings of those caps (and will typically be at least ~40% less).
Hi and thank you for replying any help to get thru this would help ok so my knowledge with electricity is beetween the middle of beginner knows a lil more then average Joe so take make it easier I don't understand wht u mean by WVDC ratings of those caps are u saying to check each cap individually? to see wht power they should be getting on cold side those caps I'm getting 24v on the hot side the big cap is 15v I can't tell it jumps like fluxiates also should I check the other big board on the right side but since it don't power on I'm assuming it has to do with the power board
