TV model - Vizio G47LFHDTV10A
Issue - After about 10 minutes, back lights flicker. Power supply voltage on 24 will waiver at that point. Checked the caps on the inverters and replaced even though test fine. I soldered most of the main spots on the power supply ( unless I missed one some wheres ). Can't figure out why the lights will flicker after a bit and turn off. Any help would be appreciated. I didn't post pics as wasn't sure what you might need but happy if you need them. No burn spots noted and caps look and test fine. No bulging. Blue caps look new. Actually a new looking board. Thanks.
