Corsair HX650W
    Corsair HX650W
    Hello.
    I hope maybe someone can help me.
    My PSU seems to be faulty but I don't know how to repair.
    I only connect it to my motherboard. When I leave the RAM out all the LEDs become green and everything stays on power. When I put a ram in the computer it comes into an on/off loop. sometimes it stays on for up to 15 seconds but I am sure the LEDs are flickering a bit. So I guess the voltage is not stable. Sounds like a broken capacitor, or can this be some kind of power management what is broken?
    Would be cool if someone know that issue and can help me with this
    (I already opened the PSU but unfortently I can't see a broken cap)
    Thanks to everybody-
    Re: Corsair HX650W
    Post a picture of both sides of the mother board in question
    Post a picture of both sides of the switching power supply in question
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Re: Corsair HX650W
      how many sticks of ram have you got and did you try them one at a time?
        Re: Corsair HX650W
        this type of symptom of an on-off boot loop is typically caused by a bad mobo or bad ram. either the ram modules are bad or the dimm slots on the board are bad. could also be a bad imc in the cpu but not likely. this is not a psu problem because the psu stays on without ram.
          Re: Corsair HX650W
          Sorry for my late answer & thanks for every reply-
          The motherboard is definitely okay, because its works like a charm with another PSU. So it has to be the PSU itself. I can open it again, but I couldn't find any optical problem. Does somebody ever had the same problem?
            Re: Corsair HX650W
            Any ideas?
              Re: Corsair HX650W
              well that coil with the burn mark needs investigating.
              did you buy this new?
              i'm not sure it's just coincidence that the heatsink above the burn has sleeving on it!!
                Re: Corsair HX650W
                no, its a used one...
                got it from a friend
                  Re: Corsair HX650W
                  better ask the friend if it was opened or anything.
