Re: $5 goodwill tower
These parts have some serious limitations. I hate to be negative but what you found is sort of the dark era of computing. For some uses it may be fine but to me this system is a reminder of how much computers have evolved without even considering raw performance and capacity increases.
- Ugly white case bezel now yellowed and white cases match nothing today.
- Poor airflow in general with little if any bezel air intake and it depends on a generic fan in the generic PSU as the only exhaust. Eek! It's surprising this thing didn't fail yet, probably doesn't have a lot of hours on it.
- The system may not have ever been run in its present config. The case is older than the motherboard and CPU. Someone may have just had a pile of parts and assembled them, and I wonder this also because of the lack of dust.
- PSU might be worth a recap but only for powering this system, not very useful for a more power hungry build. I wouldn't overclock or put a better video card in the system for example, so the power consumption stays low. Also as noted the fan is another early failure point and at the very least I'd relube it now if not replace it.
- If you only need 100Mb ethernet, then the ethernet card is actually the only part of the system with much going for it besides the CPU. Realtek cards weren't the fastest but they do fine for desktop type network access patterns. HOWEVER there is another issue. It's a PCI card, along with the PCI modem, running on a Via chipset which had terrible PCI throughput and latency issues, as well as poor memory performance. Given the Tualatin CPU it might run an old version of office ok but certainly not optimal for a fileserver or multimedia box. I'm being picky, for its era this system was probably the best bang for the buck but in retrospect, corners cut can come with consequences.
- Northbridge doesn't need a heatsink. There are no voltage settings for it AFAIK and you can't put the FSB very far past 140-something MHz if that because the PCI bus is locked at a ratio so you'll have PCI errors and potential HDD corruption if you push the FSB much further than that... meaning, northbridge won't be running much hotter with the small o'c you can get from it, otherwise you're left with 133MHz FSB and CPU multipliers which don't stress the northbridge.
I reserve the right to be wrong.
