150uF/450V replacement cap that is 18.5mmx40mm
    I am working on a monitor which needs a replacement "big" filter cap. The cap is 150uF/450V and the current one is ~ 18.2mmx40mm.
    The problem is when i go to digikey or mouser or newark.......the smallest they have is 25mmx30mm. The diameter is too big .........
    I must be doing something wrong when i go to these sites because for all of them the smallest they have is ~25mmx30mm.
    Can someone help?
    Re: 150uF/450V replacement cap that is 18.5mmx40mm
    You're doing nothing wrong. It's likely a special order cap for the manufacturer. Most in that value and close by are 22-25mm diameter.
    You could go to a 120uF/450v cap. It's at the low end of 20% tolerance of the original and would probably work just fine:
    Try mouser p/n: 647-UPZ2W121MHD - Nichicon UPZ2W121MHD - 18x40mm - $3.48
    Toast
    veritas odium parit
      Thanks. Do you really think a 120uF would work?
      On a similar question:
      If i had a 100uF cap (big filter cap) could i replace this with a 120uF cap (assuming both had same voltage specs)?
        Thanks. I will start a new thread for this 100uf being replaced by a 120uf cap.
        But back to this one..........so as a general rule of thumb.......one can go +/- 20% and you should be ok?
          As long as you stay within the +/-20% tolerance, you should be okay. Yes, you can put a 120uF in place of a 100uF.
          You can not, however, go down in voltage. But you can go up within reason. You can use a 475v or 500v cap for a 450v, but not the other way around.
          veritas odium parit
            Can someone help?
            this is very simple idea u caN USE(USED LAPTOP POWER ADAPTOR) IS MAIN CAP
            100 0R 150 UF /400 OR 450 I AM FOLLOWING THIS METHAD.
