pn64e550d1fxzc power issue
    hello i have a pn64e550d1fxzc powers off and on power supply issue ? thanks
    Re: pn64e550d1fxzc power issue
    It could be almost anything unfortunaely without some voltage readings being taken.
    Are Vs and Va trying to reach the voltage given on the label on the back of the panel?
    Have you checked to see if there is a short circuit from Va to chassis, Vs to chassis?
    Do you have photo's of your boards.
      To add onto Dick_barton's comment, it would also be nice to know more detail about the powers off issue you described. Does it turn on and work for an hour before it powers off or does it power off before picture can even appear on screen?
        tvs powered on now but sometimes it shuts of when warm? when it turns off again ill take it apart and look. any known cap issues or cold solder joints i should look for thanks
          tvs still working
            update turned tv off for 45 mins unplugged plugged it back in. within 5 mins it powered off then powered back on then i couldnt power it back on it did sit in my car last night and it was very cold.
              Touch up all the solder joints on the power supply board.
                can putting it in the oven fix the solder joints?
                  I would use a soldering iron, not an oven. You will melt all the plastic and blow up the capacitors!
                    Okay thanks all the solder joints? I haven't tooken it apart yet it won't turn on now.
                      At least do everything mounted to a heatsink and under a transformer. Use 60/40 leaded solder.
                        Thanks ill have to pick that up take it lead free won't work? And does diameter matter?
                          I use .6 to 1 mm diameter.
                            thanks never had chance to grab the solder yet. so my tv wont power on this can still be the cause
                              These 3 blue capacitors marked as 106 need to be replaced also. They are 10uf 50volt.
                              See pictures below. They will prevent the tv from turning on. They are on the y-main board.
                                Thanks what type of capacitors are they I'm use to changing electrolytic capacitors, and what rating do you recommend? Thanks
                                  I have used electrolytic caps in this repair. You have to figure out what side is the negative and the positive. I can't remember, but it was easy to figure out.
                                    thanks can you post a pic to make sure i get the right kind thsnks
                                      First picture is the recommended replacement caps. Second one is correct polarity of electrolytic capacitors. The stripe side with shorter leg is negative.
                                        thanks they just came today trying to desolder the old ones but having a hard time getting a hole for the leads using a 25w weller solder gun amd ive soldered and desoldered caps before thanks
