samsung 58 inch plasma
    Re: samsung 58 inch plasma
    I'm looking at a y sustain board and buffers on ebay. But there off the slightly newer model would they work ?
      http://pages.ebay.com/link/?nav=item...d=321312543211
        Did you try replacing fuse 1st? I'm not confident that ONLY your Y-main is bad.
        That Y-main will not work, it is from 2010 model and yours is 2009 model. Simply incompatible I'm afraid.
          Been offered a y sustain board the same as mine for £70 does that sound right ?
            Bit pricey but if you want to pay that much go for it.... personally I'm not certain if you have an X-main fault too.
              Think I need to just spend some real time on inspection on it all
                Just seen this ill check all what he has checked too
                https://www.badcaps.net/forum/showthread.php?t=29327
                  Worth a look, but remember B650 and A650 are so far apart in design despite there only being a year of difference, so take it with a pinch of salt.
                    Yer its worth a try see if I get any joy first
                      Just thought I'd havr look at this and when the t con Board when it's connected the voltage on the x sustain is all over the place disconnect from the bottom ribbon it's stable
