Hi guys i put the USB in the drive and it doesn't show on the desktop it shows on the Disks formating aplication any help thanks
lost Usb drive from desktop
Re: lost Usb drive from desktop
sounds corrupt, might need to be checkdisked, maybe you pulled it out too early (in the middle of a write cycle). If its labeled 'raw' format you might have a problem. Some recovery software might be able to recover some of it
or, there is a chance that its a multi-flash chip stick, if the first flash chip (containing the mft) has gone bad, it will request a format.Cap Datasheet Depot: http://www.paullinebarger.net/DS/
I think we need a lot more detail here. What did you plug in?
Usb memory stick
Usb Card Reader
Usb Hard drive
Usb wireless
What else have you tried to plug in ? do other things work?
Had you been reading/writing to the whatever recently.
Have you tried it on another pc/laptopPlease upload pictures using attachment function when ask for help on the repair
Thanks guys for your effort on helping,well i put in another stick with some filles in and it showed it , but the one that i had previeus formated in other pc did not show, it happed after i tried to format it with the linux aplication Gparted which i never could so i used my other win vist pc,
So i ended up by reenstalling Linux mint mate14 again that i have in a USB stick ready to go, it's much easier than trying to figuer out what hapened,
thanks.
Originally posted by Time2Retire View PostIf you had it formatted in the ext3 or ext4 file system, Windows can't read it. It will tell you it needs formatting. For Windows to read it, it would have to be a fat32 format.
