Hi all,This is my second post, and I have a general LCD monitor related question, so I am starting here and would receive instruction as to a better place to post. I am replacing the CCFL lamps in a Sceptre X22wg-1080p, and I may have changed the film layers by mistake. The bottommost layer is a reflective white sheet, then comes the Glass light guide with an etched grid on one side- and I need to know which way that etched surface goes, towards the bottom or the top, then I need the order of the two Prism Sheets (V and H), if there is a top or bottom orientation, if it makes a difference. Finally the same with the protector sheet on top of the others and below the lcd panel. I don't wanna put the thing together and have to take it apart again to turn things around. Thanks
What is the order and orientation of LCD panel layers?
Re: What is the order and orientation of LCD panel layers?
Originally posted by cheapie View PostBacklight---White Sheet---Light Guide---Polarizer---LC Panel---Polarizer---Glass is all I know.Last edited by TCI; 04-01-2013, 05:07 PM.
