I'm new to this site and new to computer repair. I fix ps3's all the time but this is uncharted territory for me so please help a noob and bare with my lack of knowledge. My xps recently started having issues, first off a few days ago the battery light started flashing orange which i found out meant the battery was going bad. I figured i had some time so i didn't buy a battery right away. Yesterday i tried to turn it on and the keyboard lights up and the system buttons to the right of the power button then everything dies. I've tried powering up with/without the battery and ac power supply. My power cord was crushed in a recliner a year ago and the blue light hasn't come on since so i can't tell if it's shorting but the charger had been working fine before this. If anyone has any ideas on how to fix this i would appreciate any input. I'm not sure if the orange battery light is related or not but from my research it sounds like it's either a short on the motherboard or a power supply problem. it's out of warranty and I'm a broke college student so I need my computer but i can't afford to drop enough for a new laptop.
dell xps L501 booting issues
Re: dell xps L501 booting issues
Start by borrowing a multimeter and test the output from the AC adapter. Match it to the output voltage on the adapter bottom sticker. Are they close ? should be around 19v. Better still if you can, you could also rule out (or in) the adapter by borrowing a known good one to try. Some Dells won't successfully boot without something of a charge showing from the battery even with AC connected. strange but true.. Had one do it last week. A Latitude D830 no sign of life until the battery had a few mins to take on a charge.Last edited by Gariarto; 03-24-2013, 06:32 PM.
I don't have another charger that i can test it with but i checked the voltage coming out of mine, and it's 19.5 which is what it's labeled output is so that's good. Is there anything externally i should check before I open it up and start trying things inside?
